<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[without really understanding, I started installing firmware as a result, the stick no longer turns on what should I do?]]></title><description><![CDATA[<p dir="auto">without really understanding, I started installing firmware as a result, the stick no longer turns on what should I do?</p>
]]></description><link>https://community.m5stack.com/topic/7094/without-really-understanding-i-started-installing-firmware-as-a-result-the-stick-no-longer-turns-on-what-should-i-do</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:45:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7094.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Dec 2024 14:51:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to without really understanding, I started installing firmware as a result, the stick no longer turns on what should I do? on Tue, 17 Dec 2024 08:36:26 GMT]]></title><description><![CDATA[<p dir="auto">open M5Burner, if you see comport detected when you connect M5Stick to usb then next step would be to burn CORRECT firmware to it as there are few versions for M5Stick</p>
]]></description><link>https://community.m5stack.com/post/27493</link><guid isPermaLink="true">https://community.m5stack.com/post/27493</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 17 Dec 2024 08:36:26 GMT</pubDate></item><item><title><![CDATA[Reply to without really understanding, I started installing firmware as a result, the stick no longer turns on what should I do? on Mon, 16 Dec 2024 19:54:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/genanann" aria-label="Profile: genanann">@<bdi>genanann</bdi></a> Erase first and then burn again.<br />
It's almost impossible to "Brick" a device.<br />
Believe me I have tried!</p>
]]></description><link>https://community.m5stack.com/post/27484</link><guid isPermaLink="true">https://community.m5stack.com/post/27484</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 16 Dec 2024 19:54:04 GMT</pubDate></item></channel></rss>
