<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CoreMP135 resize partition]]></title><description><![CDATA[<p dir="auto">The CoreMP135 is a nice little device and made a good impression when I first tested it.</p>
<p dir="auto">The file system of the debian image is quite small.</p>
<p dir="auto">Is there a way to increase the size of the root partition? The usual way with "fdisk" and "resize2fs" doesn't work. The system no longer boots.</p>
<p dir="auto">Is there a limit to the size of the FS?</p>
<p dir="auto">It would be great if future images had a larger ROOT.</p>
]]></description><link>https://community.m5stack.com/topic/7104/coremp135-resize-partition</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:46:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7104.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Dec 2024 20:33:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CoreMP135 resize partition on Sun, 22 Dec 2024 08:09:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stefanj9" aria-label="Profile: stefanj9">@<bdi>stefanj9</bdi></a> Yes, just like the older editions of Raspbian OS you have to manually run the resize script on initial startup. The command is listed on the CoreMP135 product page but it's easy to miss.<br />
My WIP guide to the CoreMP135 is going to be released next week but untill then you need to run the following command.</p>
<pre><code>./resize_mmc.sh
<p dir="auto">and hit return.</p>
]]></description><link>https://community.m5stack.com/post/27541</link><guid isPermaLink="true">https://community.m5stack.com/post/27541</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 22 Dec 2024 08:09:01 GMT</pubDate></item></channel></rss>
