<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Download program to the PaperS3]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I've just received the Paper S3.<br />
I created a program with just a print ‘Hello M5’. I can't manage to download this program to the device.</p>
<p dir="auto">The progress bar remains empty.</p>
<p dir="auto">I did flash the device with M5Burner and UIFlow2.0 PaperS3.</p>
<p dir="auto">I tested with another device, NanoC6. It does the job and the program runs.</p>
<p dir="auto">Do you have any ideas for solving the problem?<br />
Have you had this problem before? What solution did you find?</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://community.m5stack.com/topic/7122/download-program-to-the-papers3</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 17:54:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7122.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Dec 2024 11:45:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Download program to the PaperS3 on Fri, 27 Dec 2024 18:06:25 GMT]]></title><description><![CDATA[<p dir="auto">Well, I think I've made a beginner's mistake. I didn't restart PaperS3.<br />
After flashing it, I pressed the reset/boot/... button and it displayed the UiFlow page on PaperS3.</p>
<p dir="auto">Thanks for your help Felix</p>
]]></description><link>https://community.m5stack.com/post/27605</link><guid isPermaLink="true">https://community.m5stack.com/post/27605</guid><dc:creator><![CDATA[os-ronald]]></dc:creator><pubDate>Fri, 27 Dec 2024 18:06:25 GMT</pubDate></item><item><title><![CDATA[Reply to Download program to the PaperS3 on Fri, 27 Dec 2024 16:31:22 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Felix</p>
<p dir="auto">yes, I installed version 2.2.0-hotfix-2 on 2024-12-26.</p>
<p dir="auto">I plugged it in Usb. In the same way as with the NanoC6 which works.</p>
]]></description><link>https://community.m5stack.com/post/27602</link><guid isPermaLink="true">https://community.m5stack.com/post/27602</guid><dc:creator><![CDATA[os-ronald]]></dc:creator><pubDate>Fri, 27 Dec 2024 16:31:22 GMT</pubDate></item><item><title><![CDATA[Reply to Download program to the PaperS3 on Fri, 27 Dec 2024 14:29:57 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/os-ronald" aria-label="Profile: os-ronald">@<bdi>os-ronald</bdi></a></p>
<p dir="auto">hmm, both options (Run and Download) work for me (via USB connection).</p>
<p dir="auto">Which UIFlow2 firmware version did you install on your M5PaperS3? I used <code>v2.2.0-hotfix-2</code>.</p>
]]></description><link>https://community.m5stack.com/post/27599</link><guid isPermaLink="true">https://community.m5stack.com/post/27599</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 27 Dec 2024 14:29:57 GMT</pubDate></item></channel></rss>
