<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5PaperS3 wrong charger -&gt; magic smoke]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">even though I read the <a href="https://docs.m5stack.com/en/core/paperS3?id=note" target="_blank" rel="noopener noreferrer nofollow ugc">warning</a> about not using certain types of chargers with M5PaperS3 I managed to do so anyways.</p>
<p dir="auto">Suffice to say, M5Paper released some magic smoke and wouldn't start anymore.</p>
<p dir="auto">I cracked it open from the back (as I think the eInk display is glued in) to get access to the board. (I do not recommend doing that as it is a destructive process.)</p>
<p dir="auto">With the eInk display and touch disconnected I started to inspect the board.</p>
<p dir="auto">I found the <s>charger IC</s> USB-C protection diode pack being dead from the look of it. <s>I removed the charger IC (as it is not strictly needed to run)</s> I replaced the USB-C protection diode pack and found the MosFet IC getting pretty hot. So I removed the MosFet as well and injected some voltage (4.2 V) after the MosFet which revealed that the 3.3 V regulator took some hit as well. I replaced the 3.3 V regulator with a similar one I took from an M5Atom.</p>
<p dir="auto">With <s>two ICs</s> MosFet removed and the 3.3 V regulator replaced M5PaperS3 took a reasonable small amount of current. I also measured ok voltages for the eInk display so I dared to reattach the display and touch screen and yo and behold - M5PaperS3 is alive again.</p>
<p dir="auto">Now I need to order some replacement <s>ICs</s> MosFet.</p>
<p dir="auto">You can see the opened M5PaperS3 and the dead ICs <a href="https://www.gwendesign.ch/kb/m5stack/m5papers3/#inside-m5papers3" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/topic/7135/m5papers3-wrong-charger-magic-smoke</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 20:42:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7135.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Dec 2024 21:54:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5PaperS3 wrong charger -&gt; magic smoke on Thu, 09 Jan 2025 06:43:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">Update: M5PaperS3 fully <a href="https://www.gwendesign.ch/kb/m5stack/m5papers3/#restored" target="_blank" rel="noopener noreferrer nofollow ugc">restored</a> and as good as new. :-)</p>
]]></description><link>https://community.m5stack.com/post/27823</link><guid isPermaLink="true">https://community.m5stack.com/post/27823</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 09 Jan 2025 06:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to M5PaperS3 wrong charger -&gt; magic smoke on Thu, 02 Jan 2025 04:26:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
magic trick!</p>
]]></description><link>https://community.m5stack.com/post/27693</link><guid isPermaLink="true">https://community.m5stack.com/post/27693</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Thu, 02 Jan 2025 04:26:35 GMT</pubDate></item><item><title><![CDATA[Reply to M5PaperS3 wrong charger -&gt; magic smoke on Thu, 02 Jan 2025 14:59:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">while I am waiting for the replacement on / off MosFet to arrive I was able to put in a <a href="https://www.gwendesign.ch/kb/m5stack/m5papers3/#temporary-fix" target="_blank" rel="noopener noreferrer nofollow ugc">temporary fix</a> - I found a similar MosFet in an old, broken MacBook Pro. :-)</p>
]]></description><link>https://community.m5stack.com/post/27676</link><guid isPermaLink="true">https://community.m5stack.com/post/27676</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 02 Jan 2025 14:59:11 GMT</pubDate></item><item><title><![CDATA[Reply to M5PaperS3 wrong charger -&gt; magic smoke on Tue, 31 Dec 2024 11:34:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thanks for taking the time to write up about it</p>
]]></description><link>https://community.m5stack.com/post/27657</link><guid isPermaLink="true">https://community.m5stack.com/post/27657</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 31 Dec 2024 11:34:06 GMT</pubDate></item></channel></rss>
