<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PaperS3 screen stuck]]></title><description><![CDATA[<p dir="auto">I used the M5 burner to burn the UIFlow2.0 PaperS3, but now when I try to turn it off, nothing happens. Do you have any clues, please?</p>
]]></description><link>https://community.m5stack.com/topic/7147/papers3-screen-stuck</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:12:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7147.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Jan 2025 22:17:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PaperS3 screen stuck on Fri, 06 Mar 2026 03:08:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/claudiu" aria-label="Profile: claudiu">@<bdi>claudiu</bdi></a><br />
Same happen with me..I used another laptop for login and problem resolved of login<em>italicised text</em></p>
]]></description><link>https://community.m5stack.com/post/30718</link><guid isPermaLink="true">https://community.m5stack.com/post/30718</guid><dc:creator><![CDATA[Ahad_Sarah509]]></dc:creator><pubDate>Fri, 06 Mar 2026 03:08:09 GMT</pubDate></item><item><title><![CDATA[Reply to PaperS3 screen stuck on Thu, 02 Jan 2025 09:46:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> I noticed that even logging in UIFLow gives me an error on login, even if the credentials are ok. Still a lot to explore.<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/post/27714</link><guid isPermaLink="true">https://community.m5stack.com/post/27714</guid><dc:creator><![CDATA[claudiu]]></dc:creator><pubDate>Thu, 02 Jan 2025 09:46:21 GMT</pubDate></item><item><title><![CDATA[Reply to PaperS3 screen stuck on Thu, 02 Jan 2025 09:12:51 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/claudiu" aria-label="Profile: claudiu">@<bdi>claudiu</bdi></a></p>
<p dir="auto">eInk devices are a bit tricky as the screen keeps showing the last image even without power which makes it difficult to know if the device (e.g. MCU etc.) is actually running or not.</p>
<p dir="auto">As for tips: keep in mind that M5PaperS3 is a very young product and I found that not all functions are fully implemented yet. So if something doesn't work as expected this could be the reason.</p>
]]></description><link>https://community.m5stack.com/post/27709</link><guid isPermaLink="true">https://community.m5stack.com/post/27709</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 02 Jan 2025 09:12:51 GMT</pubDate></item><item><title><![CDATA[Reply to PaperS3 screen stuck on Thu, 02 Jan 2025 08:58:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> I was a bit confused. Before, I was able to press the Wi-Fi scan button and get info on the available Wi-Fi networks; now, nothing happens, and even when I press the shut-down button, nothing happens. But I did put back the factory test, and now it is behaving like before.<br />
I need to read the documentation and start using it properly :-), any tips are highly appreciated.</p>
]]></description><link>https://community.m5stack.com/post/27708</link><guid isPermaLink="true">https://community.m5stack.com/post/27708</guid><dc:creator><![CDATA[claudiu]]></dc:creator><pubDate>Thu, 02 Jan 2025 08:58:24 GMT</pubDate></item><item><title><![CDATA[Reply to PaperS3 screen stuck on Thu, 02 Jan 2025 06:49:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/claudiu" aria-label="Profile: claudiu">@<bdi>claudiu</bdi></a></p>
<p dir="auto">like <a class="plugin-mentions-user plugin-mentions-a" href="/user/kuriko" aria-label="Profile: kuriko">@<bdi>kuriko</bdi></a> already mentioned, that is the nature of an eInk screen - it retains the last picture, even w/o power.</p>
<p dir="auto">That said, I created a example in the UIFlow2 Project Zone called: <em>M5PaperS3_LED_PowerOff_UIFlow2.2.0</em> which turns on the green LED on the backside, waits 5 seconds and then powers off. (And as an indicator the green LED also turns off.)</p>
]]></description><link>https://community.m5stack.com/post/27704</link><guid isPermaLink="true">https://community.m5stack.com/post/27704</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 02 Jan 2025 06:49:42 GMT</pubDate></item><item><title><![CDATA[Reply to PaperS3 screen stuck on Thu, 02 Jan 2025 06:16:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/claudiu" aria-label="Profile: claudiu">@<bdi>claudiu</bdi></a><br />
It seems that the ink screen is like this?</p>
]]></description><link>https://community.m5stack.com/post/27702</link><guid isPermaLink="true">https://community.m5stack.com/post/27702</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Thu, 02 Jan 2025 06:16:45 GMT</pubDate></item></channel></rss>
