<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CoreS3 programming mode]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I'm trying to get my Core S3 into programming mode to reflash the demo but can't.  Pressing the reboot button down for a while makes it go green but then it goes back to normal mode.  I've tried everything to get it into the programming mode without success.  Is there anything else I can try?</p>
<p dir="auto">Steve</p>
]]></description><link>https://community.m5stack.com/topic/7151/cores3-programming-mode</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:41:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7151.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Jan 2025 18:47:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CoreS3 programming mode on Thu, 02 Jan 2025 20:13:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marnix201" aria-label="Profile: marnix201">@<bdi>marnix201</bdi></a> Weirdly it was the cable!  Tried another one and all OK.  Thanks for the help!</p>
]]></description><link>https://community.m5stack.com/post/27730</link><guid isPermaLink="true">https://community.m5stack.com/post/27730</guid><dc:creator><![CDATA[Bipman]]></dc:creator><pubDate>Thu, 02 Jan 2025 20:13:07 GMT</pubDate></item><item><title><![CDATA[Reply to CoreS3 programming mode on Thu, 02 Jan 2025 19:58:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bipman" aria-label="Profile: Bipman">@<bdi>Bipman</bdi></a></p>
<p dir="auto">Do other devices work / get recognized by your PC with the exact same cable ?<br />
Try to use another USB Cable, some Cables only have power in them and no Data wires.</p>
<p dir="auto">Try different ones (USB C to USB C, USB C to USB A )<br />
Maybe try to connect it to another PC or Laptop ?</p>
<p dir="auto">Also: try to check your Device manager to see if anything changes while plugging / unplugging the device, maybe it's a driver problem (altho normally you won't need any drivers for the S3 Devices)</p>
]]></description><link>https://community.m5stack.com/post/27729</link><guid isPermaLink="true">https://community.m5stack.com/post/27729</guid><dc:creator><![CDATA[marnix201]]></dc:creator><pubDate>Thu, 02 Jan 2025 19:58:01 GMT</pubDate></item><item><title><![CDATA[Reply to CoreS3 programming mode on Thu, 02 Jan 2025 19:48:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marnix201" aria-label="Profile: marnix201">@<bdi>marnix201</bdi></a> Thanks.  Just tried it and all as described except it doesn't find any ports.  There is no beep from the computer either to say I've attached a device.  I've tried several different USB ports on the PC too without success.</p>
]]></description><link>https://community.m5stack.com/post/27725</link><guid isPermaLink="true">https://community.m5stack.com/post/27725</guid><dc:creator><![CDATA[Bipman]]></dc:creator><pubDate>Thu, 02 Jan 2025 19:48:09 GMT</pubDate></item><item><title><![CDATA[Reply to CoreS3 programming mode on Thu, 02 Jan 2025 19:16:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bipman" aria-label="Profile: Bipman">@<bdi>Bipman</bdi></a></p>
<p dir="auto">Hi Bipman,</p>
<p dir="auto">Make sure you follow the steps below:</p>
<li>Connect the device to your PC via USB</li>
<li>Turn on the device (via the BOOT button on the top left) and wait for it to boot.</li>
<li>Now press the RESET button on the bottom right until the green light comes on and then release the button.</li>
<p dir="auto">The screen should stay black now (backlight will be on though), this means you're in programming mode.</p>
<p dir="auto">Also very important: download the latest M5Burner tool from the M5Stack website: <a href="https://docs.m5stack.com/en/uiflow/m5burner/intro" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/uiflow/m5burner/intro</a><br />
Else it won't work either.</p>
]]></description><link>https://community.m5stack.com/post/27723</link><guid isPermaLink="true">https://community.m5stack.com/post/27723</guid><dc:creator><![CDATA[marnix201]]></dc:creator><pubDate>Thu, 02 Jan 2025 19:16:08 GMT</pubDate></item></channel></rss>
