<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[8Encoder 3.3V instead of 5V]]></title><description><![CDATA[<p dir="auto">I'm using a microcontroller with 3.3V logic. How do I hook up the 8Encoder? It seems specified for 5V.</p>
<p dir="auto">Can I just power the encoder with 5V and do the i2c at 3.3V?<br />
Can I power the encoder with 3.3V? (It seems to work, but not sure if reliable.)<br />
Or should I use a logic level converter?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/7167/8encoder-3-3v-instead-of-5v</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:45:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7167.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Jan 2025 20:53:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 8Encoder 3.3V instead of 5V on Tue, 07 Jan 2025 20:45:46 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot for the fast reply. Very helpful.</p>
]]></description><link>https://community.m5stack.com/post/27800</link><guid isPermaLink="true">https://community.m5stack.com/post/27800</guid><dc:creator><![CDATA[mhuis]]></dc:creator><pubDate>Tue, 07 Jan 2025 20:45:46 GMT</pubDate></item><item><title><![CDATA[Reply to 8Encoder 3.3V instead of 5V on Mon, 06 Jan 2025 22:56:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mhuis" aria-label="Profile: mhuis">@<bdi>mhuis</bdi></a> M5Stack uses 5V on the grove cable to cover all bases!<br />
Most sensors today are 3.3V, but if one is still 5V, it will work.<br />
Then any M5Stack brand sensors will have a step down power converter to it's internal 3.3v requirement.<br />
The I2C is 3.3v.<br />
The 8 Encoder is 3.3v. on the inside (STM microcontroller).<br />
No logic level converter is needed.</p>
]]></description><link>https://community.m5stack.com/post/27787</link><guid isPermaLink="true">https://community.m5stack.com/post/27787</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Mon, 06 Jan 2025 22:56:03 GMT</pubDate></item></channel></rss>
