<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[M5Cardputer] How can I use the onboard microphone with ESP_I2S.h library?]]></title><description><![CDATA[<p dir="auto">I have a M5Stack Cardputer, which has an onboard SPM1423 microphone. In the official example code, it is driven by M5Stack's <code>M5Cardputer.h</code> and <code>Mic_Class.hpp</code>, and it works.<br />
In arduino-esp32, it provides another I2S library named <code>ESP_I2S.h</code>, which provides another way to use ESP32's I2S. I tried its example <code>Record_to_WAV.ino</code>, and changed the <code>SD_MMC.h</code> into <code>SD.h</code>. I modified the pins, set the recording time to 1 second, and it did wrote a WAV file into the TF card. But I cannot find a way to initialize the I2S properly to receive correct data.<br />
Here is my full code:</p>
<pre><code>/*
  ESP32-S2-EYE I2S record to WAV example
  This simple example demonstrates using the I2S library to record
  5 seconds of audio data and write it to a WAV file on the SD card.
  Don't forget to select the OPI PSRAM, 8MB flash size and Enable USB CDC
  on boot in the Tools menu!
  Created for arduino-esp32 on 18 Dec, 2023
  by Lucas Saavedra Vaz (lucasssvaz)
#include "ESP_I2S.h"
#include "FS.h"
#include &lt;SD.h&gt;
#include &lt;M5GFX.h&gt;
M5GFX tft;
uint16_t RGB888toRGB565(uint32_t rgb888) {
	return ((rgb888 &amp; 0x00F80000) &gt;&gt; 8) | ((rgb888 &amp; 0x0000FC00) &gt;&gt; 5) | ((rgb888 &amp; 0x000000F8) &gt;&gt; 3);
const uint8_t I2S_SCK = 43;
const uint8_t I2S_WS = -1;
const uint8_t I2S_DIN = 46;
const uint8_t SD_CMD = 14;
const uint8_t SD_CLK = 40;
const uint8_t SD_DATA0 = 39;
	// Create an instance of the I2SClass
	I2SClass i2s;
	// Create variables to store the audio data
	uint8_t *wav_buffer;
	size_t wav_size;
	// Initialize the serial port
	tft.init();
	tft.startWrite();
	tft.setBrightness(64);
	tft.fillScreen(RGB888toRGB565(0x66CCFF));
	tft.setCursor(0, 0);
	tft.setTextColor(RGB888toRGB565(0x003399));
	tft.println("Initializing I2S bus...");
	// Set up the pins used for audio input
	i2s.setPins(I2S_SCK, -1, -1, I2S_DIN);
	// Initialize the I2S bus in standard mode
	if (!i2s.begin(I2S_MODE_PDM_RX, 16000, I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_MONO, I2S_STD_SLOT_RIGHT)) {
		tft.println("Failed to initialize I2S bus!");
		return;
	tft.println("I2S bus initialized.");
	tft.println("Initializing SD card...");
	// Set up the pins used for SD card access
	SPI.begin(40, 39, 14, 12);/*SCLK, MISO, MOSI, CS*/
	SPI.setFrequency(40000000);
	// Mount the SD card
	if (!SD.begin()) {
		tft.println("Failed to initialize SD card!");
		return;
	tft.println("SD card initialized.");
	tft.println("Recording 1 second of audio data...");
	// Record 5 seconds of audio data
	wav_buffer = i2s.recordWAV(1, &amp;wav_size);
	// Create a file on the SD card
	File file = SD.open("/test.wav", FILE_WRITE);
	if (!file) {
		tft.println("Failed to open file for writing!");
		return;
	tft.println("Writing audio data to file...");
	tft.printf("Size: %d bytes\n", wav_size);
	// Write the audio data to the file
	if (file.write(wav_buffer, wav_size) != wav_size) {
		tft.println("Failed to write audio data to file!");
		return;
	// Close the file
	file.close();
	free(wav_buffer);
	tft.println("Application complete.");
	while (true);
void loop() {}
<p dir="auto">Please pay attention to the I2S initialization code.<br />
I tried several different codes to init the I2S, but none of them could get the correct audio data.</p>
<pre><code>if (!i2s.begin(I2S_MODE_PDM_RX, 16000, I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_MONO, I2S_STD_SLOT_RIGHT)) {
<p dir="auto">This one fills 0x2987 into the WAV file, and it records no sound.</p>
<pre><code>if (!i2s.begin(I2S_MODE_STD, 16000, I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_MONO, I2S_STD_SLOT_RIGHT)) {
<p dir="auto">This one fills noise into the WAV file.</p>
<pre><code>if (!i2s.begin(I2S_MODE_PDM_TX, 16000, I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_MONO, I2S_STD_SLOT_RIGHT)) {
<p dir="auto">This one writes a 0 byte WAV file.<br />
I have modified the other options of this function, but failed.</p>
<p dir="auto">How can I use the onboard microphone with <code>ESP_I2S.h</code> library?</p>
]]></description><link>https://community.m5stack.com/topic/7171/m5cardputer-how-can-i-use-the-onboard-microphone-with-esp_i2s-h-library</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:28:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7171.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jan 2025 14:42:19 GMT</pubDate><ttl>60</ttl></channel></rss>
