<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PPS 13.2 Arduino Can not compile the example Sketch]]></title><description><![CDATA[<hr />
<p dir="auto">*******Hi,<br />
I am new to the forum and have just purchased a PP2 13.2. There is an Arduino library that I wish to  use for automation . I can not compile the example Sketch for any board . So please could you tell me which chipset this example is designed to work with and then I can work out what to try and fix -</p>
<p dir="auto">As a newbie - I would also be grateful if you can tell me if the PPS 13.2 will work standalone with the arduino or whether or not I need to get something else?</p>
Simon</p>
]]></description><link>https://community.m5stack.com/topic/7186/pps-13-2-arduino-can-not-compile-the-example-sketch</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 06:20:48 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7186.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Jan 2025 14:25:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PPS 13.2 Arduino Can not compile the example Sketch on Sat, 11 Jan 2025 17:01:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thank-you - I had completely misunderstood :-)<br />
Simon</p>
]]></description><link>https://community.m5stack.com/post/27852</link><guid isPermaLink="true">https://community.m5stack.com/post/27852</guid><dc:creator><![CDATA[plackettsj1]]></dc:creator><pubDate>Sat, 11 Jan 2025 17:01:00 GMT</pubDate></item><item><title><![CDATA[Reply to PPS 13.2 Arduino Can not compile the example Sketch on Sat, 11 Jan 2025 16:39:14 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/plackettsj1" aria-label="Profile: plackettsj1">@<bdi>plackettsj1</bdi></a></p>
<p dir="auto">the PPS 13.2 module is meant to be used with an ESP32/ESP32S3 based M5Core like <a href="https://docs.m5stack.com/en/core/basic_v2.7" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack</a>, <a href="https://docs.m5stack.com/en/core/Core2%20v1.1" target="_blank" rel="noopener noreferrer nofollow ugc">M5Core2</a> or <a href="https://docs.m5stack.com/en/core/CoreS3" target="_blank" rel="noopener noreferrer nofollow ugc">M5CoreS3</a> - see PPS documentation  <a href="https://docs.m5stack.com/en/module/Module13.2-PPS" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/27850</link><guid isPermaLink="true">https://community.m5stack.com/post/27850</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 11 Jan 2025 16:39:14 GMT</pubDate></item></channel></rss>
