<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[3 things kind of odd in UIFlow2]]></title><description><![CDATA[<p dir="auto">Hi , I'm a M5Stack Fans. I'm reporting 3 thing that kind of odd in using UIFlow2.0.</p>
<li>
<p dir="auto">(with PaperS3) While setting Wifi in UIFlow (Micropython Mode), always fail , until I refresh config setting.<br />
Because I'm using UIFlow in my home after work, and in office while working. Can't link to wifi by coding, but only can do that by flash configration.</p>
</li>
<li>
<p dir="auto">I'm working with M5 vlw font converting tool. (It's owesome!! ) But it perfectly work in M5.Lcd.loadFont. But fail in drawing in buffer that built by M5.Lcd.newCanvas. (showing some random dots....)<br />
---&gt; this also happend in PaperS3.</p>
</li>
<li>
<p dir="auto">Maybe memory too small. Some code with class that inherit from the other class. It's FAIL in M5StickC, but almost success in other product. (I try it in StickC+,  Stick+2, AtomS3, Core2, and, M5Paper)</p>
</li>
]]></description><link>https://community.m5stack.com/topic/7192/3-things-kind-of-odd-in-uiflow2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:34:49 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7192.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Jan 2025 05:18:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 3 things kind of odd in UIFlow2 on Fri, 13 Jun 2025 08:57:32 GMT]]></title><description><![CDATA[<p dir="auto">UIFlow2 can feel odd due to inconsistent block behavior, limited error feedback, and occasional cloud sync issues, making it tricky for users to debug and manage projects efficiently.</p>
]]></description><link>https://community.m5stack.com/post/29243</link><guid isPermaLink="true">https://community.m5stack.com/post/29243</guid><dc:creator><![CDATA[peolsolutions]]></dc:creator><pubDate>Fri, 13 Jun 2025 08:57:32 GMT</pubDate></item><item><title><![CDATA[Reply to 3 things kind of odd in UIFlow2 on Tue, 14 Jan 2025 13:26:27 GMT]]></title><description><![CDATA[<p dir="auto">My Bad... I like to clear some mistake of my post.</p>
<li>
<p dir="auto">Excuse for my bad english. What I'm saying is when I use python code like "wifi.connect(SSID, PW)". It will fail , unless reflash configurate setting with M5Burner to the same SSID and Password setting as code.</p>
</li>
<li>
<p dir="auto">vlw font work perfectly when I change the code from "Buf=M5.Lcd.newCanvas(130,50,1,True)" to "Buf=M5.Lcd.newCanvas(130,50,16,True)". I think this might support 16bit sprite only.</p>
</li>
<li>
<p dir="auto">That only happen when I use the second UART in M5StickC (although this could be done in UIFLOW1.0).</p>
</li>
]]></description><link>https://community.m5stack.com/post/27879</link><guid isPermaLink="true">https://community.m5stack.com/post/27879</guid><dc:creator><![CDATA[phillipsback]]></dc:creator><pubDate>Tue, 14 Jan 2025 13:26:27 GMT</pubDate></item><item><title><![CDATA[Reply to 3 things kind of odd in UIFlow2 on Mon, 13 Jan 2025 05:49:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phillipsback" aria-label="Profile: phillipsback">@<bdi>phillipsback</bdi></a> If you cant access the UIFlow servers at work, it is because the work firewalls are blocking access to the server. This is a common issue and you will need to visit your IT manager about this.</p>
]]></description><link>https://community.m5stack.com/post/27870</link><guid isPermaLink="true">https://community.m5stack.com/post/27870</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 13 Jan 2025 05:49:55 GMT</pubDate></item></channel></rss>
