<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[U097 4-relay failures]]></title><description><![CDATA[<p dir="auto">We have been exploring the M5Stack to standardize on for automated board-level testing, and have three sets of fixtures designed around the modular scalable M5Stack Core2 and CoreS3.  The fixtures include the U097 4-relay module connected through the Groove port, or through a U040-B I2C expansion hub.</p>
<p dir="auto">Unfortunately, we have experienced multiple failures of the U097, characterized by relay 1 not engaging wen energized.  This has occurred with one U097 out-of-box and two during fixture verification.  Root-cause analysis of the U097 seems to indicate mechanical sticking of the LCSC 932-5VDC-SL-AH relay: if the relay is removed and the coil directly energized there is still no continuity between the switch pins, but if the relay outer case is removed it functions as expected.</p>
<p dir="auto">The relays are being used to switch signals well within their capabilities (5V, 5-50mW).</p>
<p dir="auto">Is this a known issue?  I saw another user who had an "old" and "new" U097, where the old one worked fine and the new one did not.  Has something changed?</p>
]]></description><link>https://community.m5stack.com/topic/7198/u097-4-relay-failures</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:45:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7198.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Jan 2025 21:02:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to U097 4-relay failures on Wed, 15 Jan 2025 05:42:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/journeymanwizard" aria-label="Profile: JourneymanWizard">@<bdi>JourneymanWizard</bdi></a> Please Email M5Stack support directly and PM them using twitter.</p>
]]></description><link>https://community.m5stack.com/post/27888</link><guid isPermaLink="true">https://community.m5stack.com/post/27888</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 15 Jan 2025 05:42:36 GMT</pubDate></item></channel></rss>
