<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickCPlus2 won’t boot after installing Bruce via Web Updater]]></title><description><![CDATA[<p dir="auto">When ever I try holding the power button it just shows a green light until I stop holding it. Can I fix it? I’m on a Mac Sequioa and whenever I try to reinstall it it just does the same thing. Also it just says this when I try to use any firmware on the M5Burner. Someone please help me!! It says this “ auto --port /dev/tty.usbserial-586B0029231--baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 8 flash_size detect 0x000 /Applications/M5Burner.app/Contents/Resources/packages/firmware/67e26d43292e054e605d6ec74f8163d<br />
ode-select: note: No developer tools were found, requesting install.<br />
developer tools are located at a non-default location on disk, use sudo xcode-select --switch path/to/Xcode.app to specify the Xcode t hat you wish to use for command line developer tools, and cancel the installation dialog.<br />
See man xcode-select for more details”</p>
]]></description><link>https://community.m5stack.com/topic/7206/m5stickcplus2-won-t-boot-after-installing-bruce-via-web-updater</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 22:12:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7206.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Jan 2025 12:48:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickCPlus2 won’t boot after installing Bruce via Web Updater on Thu, 16 Jan 2025 06:33:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kaidencoolkid" aria-label="Profile: kaidencoolkid">@<bdi>kaidencoolkid</bdi></a> Untill you know how the StickCplus2 works or communicates, only install UIFLow2</p>
]]></description><link>https://community.m5stack.com/post/27912</link><guid isPermaLink="true">https://community.m5stack.com/post/27912</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 16 Jan 2025 06:33:20 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickCPlus2 won’t boot after installing Bruce via Web Updater on Wed, 15 Jan 2025 19:32:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>  m5stickcplus2</p>
]]></description><link>https://community.m5stack.com/post/27909</link><guid isPermaLink="true">https://community.m5stack.com/post/27909</guid><dc:creator><![CDATA[kaidencoolkid]]></dc:creator><pubDate>Wed, 15 Jan 2025 19:32:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickCPlus2 won’t boot after installing Bruce via Web Updater on Wed, 15 Jan 2025 19:31:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> ohhhhh I did not know that thank you I will try a different one</p>
]]></description><link>https://community.m5stack.com/post/27908</link><guid isPermaLink="true">https://community.m5stack.com/post/27908</guid><dc:creator><![CDATA[kaidencoolkid]]></dc:creator><pubDate>Wed, 15 Jan 2025 19:31:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickCPlus2 won’t boot after installing Bruce via Web Updater on Wed, 15 Jan 2025 16:18:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kaidencoolkid" aria-label="Profile: kaidencoolkid">@<bdi>kaidencoolkid</bdi></a> what device? I have a video on YouTube</p>
]]></description><link>https://community.m5stack.com/post/27902</link><guid isPermaLink="true">https://community.m5stack.com/post/27902</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 15 Jan 2025 16:18:17 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickCPlus2 won’t boot after installing Bruce via Web Updater on Wed, 15 Jan 2025 16:17:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kaidencoolkid" aria-label="Profile: kaidencoolkid">@<bdi>kaidencoolkid</bdi></a> usb modem means not detected</p>
]]></description><link>https://community.m5stack.com/post/27901</link><guid isPermaLink="true">https://community.m5stack.com/post/27901</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 15 Jan 2025 16:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickCPlus2 won’t boot after installing Bruce via Web Updater on Wed, 15 Jan 2025 14:57:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a>  I’m sort of new can you help me to how to erase it when I try to update it makes like errors or something it can detect the usb it says like “usbmoddem”or something I’m on Mac should I try windows?</p>
]]></description><link>https://community.m5stack.com/post/27900</link><guid isPermaLink="true">https://community.m5stack.com/post/27900</guid><dc:creator><![CDATA[kaidencoolkid]]></dc:creator><pubDate>Wed, 15 Jan 2025 14:57:20 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickCPlus2 won’t boot after installing Bruce via Web Updater on Wed, 15 Jan 2025 14:36:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kaidencoolkid" aria-label="Profile: kaidencoolkid">@<bdi>kaidencoolkid</bdi></a> Did you know that Bruce is Hacking software like Nemo and Marauder, a Flipper Zero wannabe?</p>
<p dir="auto">Don't install this software.</p>
]]></description><link>https://community.m5stack.com/post/27897</link><guid isPermaLink="true">https://community.m5stack.com/post/27897</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 15 Jan 2025 14:36:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickCPlus2 won’t boot after installing Bruce via Web Updater on Wed, 15 Jan 2025 13:15:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kaidencoolkid" aria-label="Profile: kaidencoolkid">@<bdi>kaidencoolkid</bdi></a> tried to "erase" first? or try to install simple arduino sketch to it. Is com port detected by pc when Stic is connected to usb?</p>
]]></description><link>https://community.m5stack.com/post/27896</link><guid isPermaLink="true">https://community.m5stack.com/post/27896</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Wed, 15 Jan 2025 13:15:20 GMT</pubDate></item></channel></rss>
