<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I use an Atom Echo to &#x27;smarten&#x27; an LED string]]></title><description><![CDATA[<p dir="auto">I have an <a href="https://www.oliverbonas.com/homeware/golden-bell-christmas-garland-string-lights-340237" target="_blank" rel="noopener noreferrer nofollow ugc">Oliver Bonas LED light string</a> that has stopped working after only 2 Christmases. I also have a spare Atom Echo that I'm not using. I was wondering if I can use one of the pin outs from the Atom to control the LED string?</p>
<p dir="auto">I have disassembled the control unit and the 3 AA (1.5v but series so 4.5v) batteries are wired straight to the LED +ve wire out so I thought the 5v output pin of the atom would work (with the right resistor) but I found a post that suggests that the 5v pinout is always powered. The same post said that the other output pins (G21 / G25) are only 3.3V which I don't think is enough power for the LEDs.</p>
<p dir="auto">Any advice would be greatly apricated! Including any where I can get some starting code to make them fade in / out - assuming that's even possible.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/7211/can-i-use-an-atom-echo-to-smarten-an-led-string</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 13:50:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7211.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jan 2025 16:48:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I use an Atom Echo to &#x27;smarten&#x27; an LED string on Thu, 23 Jan 2025 19:46:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a></p>
<p dir="auto">Thanks, I'll have a look.</p>
]]></description><link>https://community.m5stack.com/post/28006</link><guid isPermaLink="true">https://community.m5stack.com/post/28006</guid><dc:creator><![CDATA[SilentSquirrel]]></dc:creator><pubDate>Thu, 23 Jan 2025 19:46:34 GMT</pubDate></item><item><title><![CDATA[Reply to Can I use an Atom Echo to &#x27;smarten&#x27; an LED string on Thu, 23 Jan 2025 19:45:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kuriko" aria-label="Profile: kuriko">@<bdi>kuriko</bdi></a></p>
<p dir="auto">Multi-pole switch and chip. The chip also dims the lights but that's not essential.</p>
<p dir="auto">Battery terminal &gt; multi pole switch to different pins to a chip &gt; LED</p>
]]></description><link>https://community.m5stack.com/post/28005</link><guid isPermaLink="true">https://community.m5stack.com/post/28005</guid><dc:creator><![CDATA[SilentSquirrel]]></dc:creator><pubDate>Thu, 23 Jan 2025 19:45:56 GMT</pubDate></item><item><title><![CDATA[Reply to Can I use an Atom Echo to &#x27;smarten&#x27; an LED string on Mon, 20 Jan 2025 13:22:47 GMT]]></title><description><![CDATA[<p dir="auto">you would need something like PWM kit to do what you need ...</p>
<p dir="auto"><a href="https://shop.m5stack.com/products/atomic-pwm-base-fdd8447l" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/atomic-pwm-base-fdd8447l</a></p>
]]></description><link>https://community.m5stack.com/post/27956</link><guid isPermaLink="true">https://community.m5stack.com/post/27956</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 20 Jan 2025 13:22:47 GMT</pubDate></item><item><title><![CDATA[Reply to Can I use an Atom Echo to &#x27;smarten&#x27; an LED string on Mon, 20 Jan 2025 10:02:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/silentsquirrel" aria-label="Profile: SilentSquirrel">@<bdi>SilentSquirrel</bdi></a><br />
How do you control your LED? Is it simply on/off or is there a driver chip?</p>
]]></description><link>https://community.m5stack.com/post/27955</link><guid isPermaLink="true">https://community.m5stack.com/post/27955</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Mon, 20 Jan 2025 10:02:48 GMT</pubDate></item></channel></rss>
