<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5PaperS3 wakeup]]></title><description><![CDATA[<p dir="auto">Hi everybody,</p>
<p dir="auto">How do you manage to get maximum battery life?<br />
What's your way to wakeup the module from sleep?<br />
It seems that the touch could not be used to wakeup.<br />
Do you have any other way and if possible with an example?</p>
<p dir="auto">Thanks in advance for your suggestions and help</p>
]]></description><link>https://community.m5stack.com/topic/7222/m5papers3-wakeup</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 19:36:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7222.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jan 2025 20:11:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5PaperS3 wakeup on Tue, 21 Jan 2025 13:25:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">I noticed that my M5PaperS3 touch screen is slightly less sensitive when running from battery. Touching the screen with more than one finger helps.</p>
<p dir="auto">Notes:</p>
<li>Touch wake-up is only possible in ESP light sleep. Please find and example <a href="https://github.com/felmue/MyM5StackExamples/blob/main/M5PaperS3/LightSleepTouchWakeup/LightSleepTouchWakeup.ino" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</li>
<li>Touch wake-up from ESP deep sleep is NOT possible as that would require the touch interrupt line to be connected to a so called RTC GPIO which is not the case in M5PaperS3.</li>
<li>Touch wake-up from shutdown mode is NOT possible as the eInk display and touch IC are not running in shutdown mode.</li>
]]></description><link>https://community.m5stack.com/post/27968</link><guid isPermaLink="true">https://community.m5stack.com/post/27968</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 21 Jan 2025 13:25:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5PaperS3 wakeup on Tue, 21 Jan 2025 10:08:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bletru" aria-label="Profile: bletru">@<bdi>bletru</bdi></a> said in <a href="/post/27961">M5PaperS3 wakeup</a>:</p>
<p dir="auto">I cannot get either to work - when on battery. When on USB power deepsleep does wake up on battery only it doesn't.</p>
<p dir="auto">Touch interrupt or timer also doesn't seem to work on battery only.</p>
]]></description><link>https://community.m5stack.com/post/27967</link><guid isPermaLink="true">https://community.m5stack.com/post/27967</guid><dc:creator><![CDATA[aleekwen]]></dc:creator><pubDate>Tue, 21 Jan 2025 10:08:13 GMT</pubDate></item></channel></rss>
