<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DC Input questions on M5dial]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Quick question on this - I was hoping to take a usbc input and route it through the dc connector (just because the panel mount I'm using has wires on the inside rather than a usb lead) but I have read that the voltage it requires is 6V minimum - so am I right in thinking I can't use a usb power in to power through the DC port? If not I'll put a usb connector on the end of the wires.</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://community.m5stack.com/topic/7229/dc-input-questions-on-m5dial</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:46:13 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7229.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Jan 2025 16:48:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DC Input questions on M5dial on Fri, 21 Feb 2025 21:27:06 GMT]]></title><description><![CDATA[<p dir="auto">I agree! USB power (5V) won’t be enough since the DC input requires at least 6V. If you’re set on using the DC port, you’d need a step-up converter. Otherwise, adding a USB connector to the wires sounds like the easier option.</p>
]]></description><link>https://community.m5stack.com/post/28297</link><guid isPermaLink="true">https://community.m5stack.com/post/28297</guid><dc:creator><![CDATA[Slarck]]></dc:creator><pubDate>Fri, 21 Feb 2025 21:27:06 GMT</pubDate></item><item><title><![CDATA[Reply to DC Input questions on M5dial on Fri, 24 Jan 2025 06:32:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/louisandthecat" aria-label="Profile: louisandthecat">@<bdi>louisandthecat</bdi></a> It probably is correct due to the losses from the internal power regulator.</p>
]]></description><link>https://community.m5stack.com/post/28009</link><guid isPermaLink="true">https://community.m5stack.com/post/28009</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 24 Jan 2025 06:32:33 GMT</pubDate></item></channel></rss>
