<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Driver Windows for M5 Stickc Plus2]]></title><description><![CDATA[<p dir="auto">Hello.<br />
I installed the driver CH9102_VCP_SER_Windows  <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CH9102_VCP_SER_Windows.exe" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CH9102_VCP_SER_Windows.exe</a>  .  But when connected via USB - Type C cable, my device is not displayed in the device manager. There are no COM ports in M5Burner (they are not displayed).</p>
<p dir="auto">Please, help me</p>
<p dir="auto">OS: Windows 11<br />
M5Stack Stickc Plus 2</p>
]]></description><link>https://community.m5stack.com/topic/7231/driver-windows-for-m5-stickc-plus2</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 19:48:38 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7231.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Jan 2025 03:08:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Driver Windows for M5 Stickc Plus2 on Sat, 03 Jan 2026 06:20:47 GMT]]></title><description><![CDATA[<p dir="auto">@mrconstanti,</p>
<p dir="auto">I found on Win 11 don't work really the USB / Serial driver from M5Stack.<br />
I found after some own Trouble with can't find device the driver developer with an update driver also for Win 11. (Driver year 2025)</p>
<p dir="auto">I test, unknown device still exist, but I think with Arduino IDE can work, until now my own project stopped with some other errors, so I'm not sure to 100% but if help other and you.</p>
<p dir="auto"><a href="https://www.wch-ic.com/downloads/CH343SER_ZIP.html" target="_blank" rel="noopener noreferrer nofollow ugc">wch-ic.com</a></p>
<p dir="auto">Kind regards<br />
Chris</p>
]]></description><link>https://community.m5stack.com/post/30400</link><guid isPermaLink="true">https://community.m5stack.com/post/30400</guid><dc:creator><![CDATA[ChrigiGee]]></dc:creator><pubDate>Sat, 03 Jan 2026 06:20:47 GMT</pubDate></item><item><title><![CDATA[Reply to Driver Windows for M5 Stickc Plus2 on Sat, 08 Feb 2025 02:43:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrconstantine" aria-label="Profile: mrconstantine">@<bdi>mrconstantine</bdi></a><br />
You can check the Sorfware antivirus or Microsoft Defender or the app that prevents or blocks the operation. Maybe you have set the system to prevent the operation of the external app. And try to check your cable is a data cable or just charging. If it is charging only, it will not be able to connect. By testing with other devices, observe whether the device being tested has a serial port or not. If the tested device does not have a port, it means that your cable does not support data transfer. You need to find a new cable that supports data transfer.</p>
]]></description><link>https://community.m5stack.com/post/28143</link><guid isPermaLink="true">https://community.m5stack.com/post/28143</guid><dc:creator><![CDATA[RossFall]]></dc:creator><pubDate>Sat, 08 Feb 2025 02:43:24 GMT</pubDate></item><item><title><![CDATA[Reply to Driver Windows for M5 Stickc Plus2 on Wed, 05 Feb 2025 06:22:21 GMT]]></title><description><![CDATA[<p dir="auto">@dmarinho Is it blocked by OSX security system?<br />
Have you checked cables?<br />
Did you reboot the Mac after installing the driver and before connecting the Stick?<br />
Mac have been doing some strange things with security of late.</p>
]]></description><link>https://community.m5stack.com/post/28116</link><guid isPermaLink="true">https://community.m5stack.com/post/28116</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 05 Feb 2025 06:22:21 GMT</pubDate></item><item><title><![CDATA[Reply to Driver Windows for M5 Stickc Plus2 on Tue, 04 Feb 2025 17:24:31 GMT]]></title><description><![CDATA[<p dir="auto">I installed this driver on the Mac M1, but I had a connection problem that I didn't have before, I uninstalled it.</p>
<p dir="auto">Now I can't connect the m5 to the USB like before, can you help me, because it only opens the console port, bluetouch, and debug!!thanks in advance!</p>
]]></description><link>https://community.m5stack.com/post/28105</link><guid isPermaLink="true">https://community.m5stack.com/post/28105</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 04 Feb 2025 17:24:31 GMT</pubDate></item><item><title><![CDATA[Reply to Driver Windows for M5 Stickc Plus2 on Thu, 23 Jan 2025 11:32:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrconstantine" aria-label="Profile: mrconstantine">@<bdi>mrconstantine</bdi></a> in most cases it’s bad cables. When buying them make sure to get data cables as power/charge cables don’t have the data wires</p>
]]></description><link>https://community.m5stack.com/post/28001</link><guid isPermaLink="true">https://community.m5stack.com/post/28001</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 23 Jan 2025 11:32:20 GMT</pubDate></item><item><title><![CDATA[Reply to Driver Windows for M5 Stickc Plus2 on Thu, 23 Jan 2025 08:23:03 GMT]]></title><description><![CDATA[<p dir="auto">Thank you!<br />
I connected the device with another USB cable. Now the COM port is displayed and the device is visible</p>
]]></description><link>https://community.m5stack.com/post/28000</link><guid isPermaLink="true">https://community.m5stack.com/post/28000</guid><dc:creator><![CDATA[mrconstantine]]></dc:creator><pubDate>Thu, 23 Jan 2025 08:23:03 GMT</pubDate></item><item><title><![CDATA[Reply to Driver Windows for M5 Stickc Plus2 on Thu, 23 Jan 2025 07:57:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Yes, I rebooted the laptop with the Windows operating system. It did not help. I did not try another USB cable.</p>
<p dir="auto">And what are the characteristics of the USB cable? What should the cable be?</p>
]]></description><link>https://community.m5stack.com/post/27999</link><guid isPermaLink="true">https://community.m5stack.com/post/27999</guid><dc:creator><![CDATA[mrconstantine]]></dc:creator><pubDate>Thu, 23 Jan 2025 07:57:32 GMT</pubDate></item><item><title><![CDATA[Reply to Driver Windows for M5 Stickc Plus2 on Thu, 23 Jan 2025 07:17:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrconstantine" aria-label="Profile: mrconstantine">@<bdi>mrconstantine</bdi></a> have you fully shutdown your windows computer and cold booted it from a powered off state?</p>
<p dir="auto">Have you tried a different usb cable?</p>
]]></description><link>https://community.m5stack.com/post/27996</link><guid isPermaLink="true">https://community.m5stack.com/post/27996</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 23 Jan 2025 07:17:19 GMT</pubDate></item></channel></rss>
