<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Paper loosing power completely]]></title><description><![CDATA[<p dir="auto">I would like to use M5Paper with ESPHome, and I have trouble with shutdown.<br />
After a couple of wake-shutdown cycle, the device loose power completely, which means it cannot wake up from RTC.<br />
Buttons do not do anything, only way to wake it up is via USB connected.<br />
The strange thing is, RTC get's resetted as well, every time this happens, RTC is back to 0:0, so no wonder why wakeup was not working.<br />
How is it possible to RTC to loose power, I thought it is directly connected to the battery.</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://community.m5stack.com/topic/7243/m5paper-loosing-power-completely</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 07:40:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7243.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Jan 2025 13:15:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Paper loosing power completely on Wed, 29 Jan 2025 17:05:21 GMT]]></title><description><![CDATA[<p dir="auto">Looks like it has to do something with the bootloader.<br />
I previously flashed the full factory-firmware which comes out of ESHome(platformio) build, but if I just flash the firmware to 0x10000, then it boots up all the time from battery as well. Needs more digging what could go wrong with platformio bootloader.</p>
]]></description><link>https://community.m5stack.com/post/28066</link><guid isPermaLink="true">https://community.m5stack.com/post/28066</guid><dc:creator><![CDATA[zoli0726]]></dc:creator><pubDate>Wed, 29 Jan 2025 17:05:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper loosing power completely on Wed, 29 Jan 2025 09:49:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>. Yes, the battery is fully charged, also interrestingly the code is stable when running from  USB power. After disconnecting, and a coupde of shutdown-wakeup cycles passes, it freezes. I'm also monitoring the battery voltage, and its well above empty. I dont think it would even have enough time to discharge, since its happening after 15-20 mins, when disconnected from USB.</p>
<p dir="auto">The device can shutdown-wakeup indefinitely if I build projects in Arduino ide, so for now I would say it is unlikely a hw issue.</p>
]]></description><link>https://community.m5stack.com/post/28064</link><guid isPermaLink="true">https://community.m5stack.com/post/28064</guid><dc:creator><![CDATA[zoli0726]]></dc:creator><pubDate>Wed, 29 Jan 2025 09:49:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper loosing power completely on Mon, 27 Jan 2025 15:44:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zoli0726" aria-label="Profile: zoli0726">@<bdi>zoli0726</bdi></a> have you remembered to make sure the paper is charged fully?</p>
]]></description><link>https://community.m5stack.com/post/28048</link><guid isPermaLink="true">https://community.m5stack.com/post/28048</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 27 Jan 2025 15:44:13 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper loosing power completely on Mon, 27 Jan 2025 12:39:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/zoli0726" aria-label="Profile: zoli0726">@<bdi>zoli0726</bdi></a></p>
<p dir="auto">what you describe points to an empty battery. How long did you charge the battery?</p>
]]></description><link>https://community.m5stack.com/post/28045</link><guid isPermaLink="true">https://community.m5stack.com/post/28045</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 27 Jan 2025 12:39:32 GMT</pubDate></item></channel></rss>
