<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOMS3 IMU - wake up device]]></title><description><![CDATA[<p dir="auto">Hi all kind people,</p>
<p dir="auto">i have AtomS3 and Nb-iot2 module. I am pretty much beginner here, but with assitance of ChatGPT my first project is alive, but have big power consumption 0,061A.</p>
<p dir="auto">My program: device is on and wifi and ble are off, device is waiting for first move, if move is detected then Nbiot2 turn on, connect, send webhook, turn off the screen and go to the sleep and waiting for the next move from IMU.</p>
<p dir="auto">But here is my problem: if i use command for deep sleep the device cannot be wake up when is moving.</p>
<p dir="auto">My goal is something about 6-10mA ---- in theore i want to live one month on 21700 battery.</p>
<p dir="auto">Can anyone please help me, how can i make the light or deep sleep on device to have lower consumption?</p>
<p dir="auto">I have all Stamp and Atom and Stick devices and when that will work i want make this project for StamS3.</p>
]]></description><link>https://community.m5stack.com/topic/7267/atoms3-imu-wake-up-device</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 10:22:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7267.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Feb 2025 19:14:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOMS3 IMU - wake up device on Mon, 03 Mar 2025 09:54:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/myscho151" aria-label="Profile: myscho151">@<bdi>myscho151</bdi></a></p>
<p dir="auto">you could use an <a href="https://docs.m5stack.com/en/core/m5stickc_plus" target="_blank" rel="noopener noreferrer nofollow ugc">M5StickCPlus</a> - see stock example <a href="https://github.com/m5stack/M5StickC-Plus/blob/master/examples/Advanced/IMU_Wake_On_Motion/IMU_Wake_On_Motion.ino" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/28373</link><guid isPermaLink="true">https://community.m5stack.com/post/28373</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 03 Mar 2025 09:54:19 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 IMU - wake up device on Sun, 02 Mar 2025 22:20:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thank you. But i see you wirite in your post that i can use my M5 Stick (the newest version) - because you write that the Stick have this connection i need?</p>
]]></description><link>https://community.m5stack.com/post/28371</link><guid isPermaLink="true">https://community.m5stack.com/post/28371</guid><dc:creator><![CDATA[myscho151]]></dc:creator><pubDate>Sun, 02 Mar 2025 22:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 IMU - wake up device on Fri, 14 Feb 2025 20:10:14 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/myscho151" aria-label="Profile: myscho151">@<bdi>myscho151</bdi></a></p>
<p dir="auto">if you have access to a soldering station you could connect the INT line to a GPIO yourself. I've done that for am M5Core2 - please see <a href="https://www.gwendesign.ch/kb/m5stack/m5core2/#wake-on-motion-wom-using-mpu6886-interrupt" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/28229</link><guid isPermaLink="true">https://community.m5stack.com/post/28229</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 14 Feb 2025 20:10:14 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 IMU - wake up device on Fri, 14 Feb 2025 19:50:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thank you for your time. I am noob about this, but i is big disadvantage :-( i must find some better IMU unit for this project.</p>
]]></description><link>https://community.m5stack.com/post/28228</link><guid isPermaLink="true">https://community.m5stack.com/post/28228</guid><dc:creator><![CDATA[myscho151]]></dc:creator><pubDate>Fri, 14 Feb 2025 19:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 IMU - wake up device on Sun, 09 Feb 2025 20:55:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/myscho151" aria-label="Profile: myscho151">@<bdi>myscho151</bdi></a></p>
<p dir="auto">unfortunately both IMU units you linked 'suffer' from the same issue as the IMU internal to M5AtomS3 - the INT line is <strong>not</strong> connected.</p>
]]></description><link>https://community.m5stack.com/post/28162</link><guid isPermaLink="true">https://community.m5stack.com/post/28162</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 09 Feb 2025 20:55:38 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 IMU - wake up device on Sun, 09 Feb 2025 18:22:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thank you very much. Looks you understand my problem, so if i use for example AtomS3 lite or Stamp and i will use external accelerometer - i have both... is way to wake up device? Using of AtomS3 is not neccesary, but i start with this device (because display give me some feedback).</p>
<p dir="auto">I have this IMU units:</p>
<p dir="auto"><a href="https://shop.m5stack.com/products/6-axis-imu-unitmpu6886?srsltid=AfmBOopYP0BxUe1c-m8CkWPCuHO8tqyQ0TsQsLKVjlZl6HxUFQ6080gP" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/6-axis-imu-unitmpu6886?srsltid=AfmBOopYP0BxUe1c-m8CkWPCuHO8tqyQ0TsQsLKVjlZl6HxUFQ6080gP</a></p>
<p dir="auto"><a href="https://shop.m5stack.com/products/6-dof-imu-pro-mini-unit-bmi270-bmm150-bmp280" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/6-dof-imu-pro-mini-unit-bmi270-bmm150-bmp280</a></p>
<p dir="auto">Because i find that one have IMU6886 and second BMI270.</p>
<p dir="auto">But in overall is hard for me find some more infos. Like i fight with NB-iOT2 module to make it work, but AI help me.</p>
]]></description><link>https://community.m5stack.com/post/28160</link><guid isPermaLink="true">https://community.m5stack.com/post/28160</guid><dc:creator><![CDATA[myscho151]]></dc:creator><pubDate>Sun, 09 Feb 2025 18:22:41 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 IMU - wake up device on Tue, 04 Feb 2025 21:57:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/myscho151" aria-label="Profile: myscho151">@<bdi>myscho151</bdi></a></p>
<p dir="auto">I don't think you can wake ESP32S3 from deep or light sleep when IMU is registering movement. Reason: the INT line of IMU in M5AtomS3 is not connected to anything. So I don't see how IMU could signal ESP32S3 to wake up.</p>
]]></description><link>https://community.m5stack.com/post/28109</link><guid isPermaLink="true">https://community.m5stack.com/post/28109</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 04 Feb 2025 21:57:28 GMT</pubDate></item></channel></rss>
