<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help With LiidarBot Functions]]></title><description><![CDATA[<p dir="auto">Hello Friends,</p>
<p dir="auto">I Recently purchased a LidarBot and have a couple of questions.</p>
<p dir="auto">Is the C button on remote supposed to turn on the LED strip?<br />
If so, mine does not - How would I solve this?</p>
<p dir="auto">Second is the use of C button on Bot - It does not put any options up for the mode. How can I change the mode from remote mode to maze mode?</p>
<p dir="auto">Do I need to use the Easy Loader for both the Bot and the remote in order to get these functions to work or am I doing something wrong.</p>
<p dir="auto">Thanks, Donnie Alfonso</p>
]]></description><link>https://community.m5stack.com/topic/7321/help-with-liidarbot-functions</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 08:33:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7321.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 23 Feb 2025 01:34:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help With LiidarBot Functions on Sun, 23 Feb 2025 19:44:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Batteries are plugged in and button pressed to turn BOT on and can move it around with the remote.</p>
<p dir="auto">Is there something else on the BOT to turn on other than the chrome push button?</p>
<p dir="auto">When I move the BOT blue LEDs light and when I first push the push button the while bright LEDs flash on and off.<br />
 <br />
Thanks.</p>
]]></description><link>https://community.m5stack.com/post/28314</link><guid isPermaLink="true">https://community.m5stack.com/post/28314</guid><dc:creator><![CDATA[lenswerks]]></dc:creator><pubDate>Sun, 23 Feb 2025 19:44:27 GMT</pubDate></item><item><title><![CDATA[Reply to Help With LiidarBot Functions on Sun, 23 Feb 2025 18:58:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lenswerks" aria-label="Profile: lenswerks">@<bdi>lenswerks</bdi></a> You have plugged in the 2 X 12 volt batteries and turned the base on?</p>
]]></description><link>https://community.m5stack.com/post/28313</link><guid isPermaLink="true">https://community.m5stack.com/post/28313</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 23 Feb 2025 18:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to Help With LiidarBot Functions on Sun, 23 Feb 2025 17:59:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lenswerks" aria-label="Profile: lenswerks">@<bdi>lenswerks</bdi></a> Okay found the Lidbot firmware on M5Burner. Published 2023. Not sure why something published in 2023 is going to be more current than what is on a Bot received two weeks ago.</p>
<p dir="auto">Erased then burned both remote and Bot. Made no difference.</p>
<p dir="auto">Unable to turn on LED bar.<br />
Unable to display option to change modes.</p>
<p dir="auto">Anyone else have one of these with recommendations?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/post/28312</link><guid isPermaLink="true">https://community.m5stack.com/post/28312</guid><dc:creator><![CDATA[lenswerks]]></dc:creator><pubDate>Sun, 23 Feb 2025 17:59:07 GMT</pubDate></item><item><title><![CDATA[Reply to Help With LiidarBot Functions on Sun, 23 Feb 2025 11:57:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> I do not see any Lindar firmware option on M5Burner site. Can I use EasyLoader to burn?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/post/28310</link><guid isPermaLink="true">https://community.m5stack.com/post/28310</guid><dc:creator><![CDATA[lenswerks]]></dc:creator><pubDate>Sun, 23 Feb 2025 11:57:28 GMT</pubDate></item><item><title><![CDATA[Reply to Help With LiidarBot Functions on Sun, 23 Feb 2025 08:59:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lenswerks" aria-label="Profile: lenswerks">@<bdi>lenswerks</bdi></a> Strange behaviour.<br />
Use M5Burner to erase and burn the latest lidarbot firmware.</p>
]]></description><link>https://community.m5stack.com/post/28308</link><guid isPermaLink="true">https://community.m5stack.com/post/28308</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 23 Feb 2025 08:59:40 GMT</pubDate></item></channel></rss>
