<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Copy Firmware from One M5 to Another]]></title><description><![CDATA[<p dir="auto">I loaded some custom ESP Home firmware onto an M5 Atom Echo. It works fine but the speaker makes chirping noises. I would like to transfer the firmware to an M5 AtomS3 Lite. What is the preferred and easiest way to do that? I am a novice with this tech so I thought I would ask the experts. The reason that I am asking is I like to have backup hardware in case one fails that I can plug in without having to do any software loading and configuration for some critical IOT devices.</p>
]]></description><link>https://community.m5stack.com/topic/7331/copy-firmware-from-one-m5-to-another</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:56:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7331.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Feb 2025 20:20:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Copy Firmware from One M5 to Another on Thu, 27 Feb 2025 17:16:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> That is what I suspected. Thank you.</p>
]]></description><link>https://community.m5stack.com/post/28346</link><guid isPermaLink="true">https://community.m5stack.com/post/28346</guid><dc:creator><![CDATA[chpaaa1]]></dc:creator><pubDate>Thu, 27 Feb 2025 17:16:28 GMT</pubDate></item><item><title><![CDATA[Reply to Copy Firmware from One M5 to Another on Thu, 27 Feb 2025 05:48:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chpaaa1" aria-label="Profile: chpaaa1">@<bdi>chpaaa1</bdi></a> You will need to rebuild the firmware from scratch as the ESP32's in the Echo and S3 are not the same.<br />
There are enough hardware differences that make them incompatible.</p>
]]></description><link>https://community.m5stack.com/post/28343</link><guid isPermaLink="true">https://community.m5stack.com/post/28343</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 27 Feb 2025 05:48:21 GMT</pubDate></item></channel></rss>
