<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is the IO extended unit (U011-B) also compatible with the M5StickC Plus?]]></title><description><![CDATA[<p dir="auto">I am using the M5StickC Plus and want to use the following functionalities simultaneously:</p>
<li>list itemWiFi connection</li>
<li>Four analog inputs</li>
<li>IMU data retrieval</li>
<p dir="auto">However, I realized that when WiFi is in use, only up to three analog inputs can be used.</p>
<p dir="auto">Question 1:<br />
Is there a way to use four analog inputs while using WiFi?</p>
<p dir="auto">Question 2:<br />
As a solution for not being able to use four analog inputs, I found an I/O expansion unit called U011-B.<br />
<a href="https://www.electromaker.io/shop/product/extend-io-2-unitstm32f0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.electromaker.io/shop/product/extend-io-2-unitstm32f0</a><br />
This is designed for M5Stack, but is it also compatible with M5StickC Plus?</p>
]]></description><link>https://community.m5stack.com/topic/7333/is-the-io-extended-unit-u011-b-also-compatible-with-the-m5stickc-plus</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 23:31:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7333.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Feb 2025 16:36:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is the IO extended unit (U011-B) also compatible with the M5StickC Plus? on Thu, 06 Mar 2025 02:02:39 GMT]]></title><description><![CDATA[<p dir="auto">I bought and tested an I/O expansion unit called U011-B.</p>
<p dir="auto">As a result, I was able to successfully read four I/O signals from the M5StickC Plus from U011-B during using WiFi.</p>
]]></description><link>https://community.m5stack.com/post/28403</link><guid isPermaLink="true">https://community.m5stack.com/post/28403</guid><dc:creator><![CDATA[mutsuyuki_]]></dc:creator><pubDate>Thu, 06 Mar 2025 02:02:39 GMT</pubDate></item></channel></rss>
