<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CoreInk display fades]]></title><description><![CDATA[<p dir="auto">Hi, I'm trying to solve fading display color. After a few cycles of light sleep CoreInk dispay becomes pale. I found a post with solution for UiFlow ver.1 <a href="https://community.m5stack.com/topic/3158/core-ink-screen-fades-on-reset">https://community.m5stack.com/topic/3158/core-ink-screen-fades-on-reset</a></p>
<p dir="auto">How can I achieve the same with UiFlow2? Is there a "Set Screen HV" block? Or what is the equivalent in python?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/7341/coreink-display-fades</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:41:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7341.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 Feb 2025 11:14:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CoreInk display fades on Wed, 19 Mar 2025 17:45:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/desmbr" aria-label="Profile: desmbr">@<bdi>desmbr</bdi></a></p>
<p dir="auto">indeed, that doesn't look good. I wonder if maybe the internal battery is defective preventing the power rails from reaching the proper voltages.</p>
<p dir="auto">Edit: first, however I would unplug the hat and maybe try a different USB power supply.</p>
<p dir="auto">If you still have warranty, I suggest you ask for a replacement.</p>
<p dir="auto">If not, you might try to open it and disconnect the battery to see if that helps. These <a href="https://gwendesign.ch/kb/m5stack/m5coreink/" target="_blank" rel="noopener noreferrer nofollow ugc">pictures</a> I took a while ago might be helpful opening M5CoreInk.</p>
]]></description><link>https://community.m5stack.com/post/28555</link><guid isPermaLink="true">https://community.m5stack.com/post/28555</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 19 Mar 2025 17:45:45 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Mon, 17 Mar 2025 15:48:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> said in <a href="/post/28507">CoreInk display fades</a>:</p>
<p dir="auto">have you checked the boot option? In M5Burner click onto the <code>Configure</code> (yellow) button and then set <code>Boot Option</code> to <code>Show startup menu and network setup</code>. Then click onto <code>Next</code> to set the new boot option.</p>
<p dir="auto">As I mentioned before, I tried that. The screen flashes a few times and then it is blank and I only see a vertical line on the right. If you look closer there are slightly whiter traces of UI</p>
<p dir="auto">This is how it behaves: <a href="https://youtube.com/shorts/s7ljTruGtDk" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtube.com/shorts/s7ljTruGtDk</a></p>
<p dir="auto">And this is what remains: <img src="/assets/uploads/files/1742225555531-b44e18e6-eac2-4f64-8fbf-72d073483c06-image.png" alt="b44e18e6-eac2-4f64-8fbf-72d073483c06-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/28536</link><guid isPermaLink="true">https://community.m5stack.com/post/28536</guid><dc:creator><![CDATA[desmbr]]></dc:creator><pubDate>Mon, 17 Mar 2025 15:48:48 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Fri, 14 Mar 2025 09:16:59 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/desmbr" aria-label="Profile: desmbr">@<bdi>desmbr</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/28507</link><guid isPermaLink="true">https://community.m5stack.com/post/28507</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 14 Mar 2025 09:16:59 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Tue, 11 Mar 2025 13:38:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> ,</p>
<p dir="auto">I disconnected everything. Updated UiFlow to 2.2.3.<br />
After complete reset I see Ui logo, then for a second I see startup menu and then screen blinks and everything disappears.</p>
]]></description><link>https://community.m5stack.com/post/28464</link><guid isPermaLink="true">https://community.m5stack.com/post/28464</guid><dc:creator><![CDATA[desmbr]]></dc:creator><pubDate>Tue, 11 Mar 2025 13:38:10 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Tue, 11 Mar 2025 08:55:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/desmbr" aria-label="Profile: desmbr">@<bdi>desmbr</bdi></a></p>
<p dir="auto">hmm, yes, that doesn't look good.</p>
<p dir="auto">Have you tried without the hat connected?</p>
<p dir="auto">Have you tried when running from battery?</p>
<p dir="auto">Have you tried to fully power off / on M5CoreInk? E.g.</p>
<li>disconnect USB-C</li>
<li>press and hold RST button in the back for 5 seconds</li>
<li>turn back on via side button (or by plugging in USB-C)</li>
<p dir="auto">Also, are you running the latest UIFlow2 v2.2.3 firmware? Maybe use M5Burner to fully erase first and then reinstall UIFlow2 v2.2.3?</p>
]]></description><link>https://community.m5stack.com/post/28462</link><guid isPermaLink="true">https://community.m5stack.com/post/28462</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 11 Mar 2025 08:55:03 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Tue, 11 Mar 2025 08:22:24 GMT]]></title><description><![CDATA[<p dir="auto">There is something wrong with my device then.. This is what I see with your example project: <img src="/assets/uploads/files/1741681342511-3db54d18-b216-4753-85ee-1759b5fb8fef-image.png" alt="3db54d18-b216-4753-85ee-1759b5fb8fef-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/28455</link><guid isPermaLink="true">https://community.m5stack.com/post/28455</guid><dc:creator><![CDATA[desmbr]]></dc:creator><pubDate>Tue, 11 Mar 2025 08:22:24 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Mon, 10 Mar 2025 16:50:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/desmbr" aria-label="Profile: desmbr">@<bdi>desmbr</bdi></a></p>
<p dir="auto">I created an UIFlow2 light sleep example for M5CoreInk but I cannot confirm the display fading you are reporting.</p>
<p dir="auto">You can find my example in the UIFlow2 ProjectZone called: <em>M5CoreInk_LightSleep_Test_UIFlow2.2.3</em></p>
]]></description><link>https://community.m5stack.com/post/28447</link><guid isPermaLink="true">https://community.m5stack.com/post/28447</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 10 Mar 2025 16:50:55 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Mon, 10 Mar 2025 08:27:49 GMT]]></title><description><![CDATA[<p dir="auto">Sorry for bumping the topic, but I would really appreciate any kind of advice. I suppose missing <code>Set screen HV</code> block in UIFlow2.0 is a gap and is probably planned in a future release?</p>
<p dir="auto">Is there an equivalent in python code for that?</p>
]]></description><link>https://community.m5stack.com/post/28440</link><guid isPermaLink="true">https://community.m5stack.com/post/28440</guid><dc:creator><![CDATA[desmbr]]></dc:creator><pubDate>Mon, 10 Mar 2025 08:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Sun, 02 Mar 2025 10:05:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> ,<br />
That is what I'm asking :) I don't see which widget/code can do so. Can you show an example please?</p>
<p dir="auto">Btw, what does HV stand for?</p>
]]></description><link>https://community.m5stack.com/post/28368</link><guid isPermaLink="true">https://community.m5stack.com/post/28368</guid><dc:creator><![CDATA[desmbr]]></dc:creator><pubDate>Sun, 02 Mar 2025 10:05:02 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk display fades on Fri, 28 Feb 2025 18:19:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/desmbr" aria-label="Profile: desmbr">@<bdi>desmbr</bdi></a> If you want data to remain visible after shutdown or sleep, you do as you have surmised have to trigger the Screen HV, write the data then shut down.<br />
The fading without the set screen HV is normal.</p>
]]></description><link>https://community.m5stack.com/post/28364</link><guid isPermaLink="true">https://community.m5stack.com/post/28364</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 28 Feb 2025 18:19:25 GMT</pubDate></item></channel></rss>
