<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is the Battery Module for ESP32 Core Development Kit compatible with M5Stack Fire 2.7]]></title><description><![CDATA[<p dir="auto">Hello guys,</p>
<p dir="auto">I want to add more battery to my M5Stack Fire 2.7, and I would like to know if this module <a href="https://shop.m5stack.com/products/battery-module" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/battery-module</a> is compatible with my M5Stack Fire.</p>
<p dir="auto">By that, where can I find screws to assemble everything together, so my clients, don't disassembly the parts?</p>
]]></description><link>https://community.m5stack.com/topic/7343/is-the-battery-module-for-esp32-core-development-kit-compatible-with-m5stack-fire-2-7</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 16:18:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7343.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 Feb 2025 16:19:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is the Battery Module for ESP32 Core Development Kit compatible with M5Stack Fire 2.7 on Tue, 03 Jun 2025 11:57:37 GMT]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">Yes, the M5Stack Battery Module works with the M5Stack Fire 2.7. M5Stack's stackable header-pin design allows you to simply add modules like this one without needing to solder.</p>
<p dir="auto">Use M2 screws (22mm or longer) and M2 brass spacers to securely assemble everything. This maintains the modules securely packed, which is ideal for preventing inadvertent disassembly, particularly in client-facing installations.</p>
<p dir="auto">If you are in India, check out Robocraze. They are an approved <strong><a href="https://robocraze.com/pages/m5stack" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack</a></strong> distributor, providing accessories and assistance for clean, professional builds.</p>
<p dir="auto">Hope this helps!</p>
]]></description><link>https://community.m5stack.com/post/29161</link><guid isPermaLink="true">https://community.m5stack.com/post/29161</guid><dc:creator><![CDATA[sanjaay]]></dc:creator><pubDate>Tue, 03 Jun 2025 11:57:37 GMT</pubDate></item></channel></rss>
