<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to disable M5stack fire power saving]]></title><description><![CDATA[<p dir="auto">Hello guys, how can I disable the power saving on M5Stack Fire, so even if the battery is below 25% the M5Stack stills running?</p>
<p dir="auto">I tried this</p>
<p dir="auto">M5.Power.setPowerBoostKeepOn(true);<br />
But didn't work, as expected.</p>
<p dir="auto">Any solutions?</p>
]]></description><link>https://community.m5stack.com/topic/7367/how-to-disable-m5stack-fire-power-saving</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:12:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7367.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Mar 2025 10:19:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to disable M5stack fire power saving on Fri, 14 Mar 2025 09:06:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/peolsolutions" aria-label="Profile: peolsolutions">@<bdi>peolsolutions</bdi></a></p>
<p dir="auto">just an FYI: M5Stack Fire doesn't have an AXP192 PMU.</p>
<p dir="auto">I get the feeling some of your posts are AI generated, no? If I am correct I'd appreciate if you could first verify the technical facts before posting.</p>
<p dir="auto">Thank you very much for your understanding.</p>
]]></description><link>https://community.m5stack.com/post/28505</link><guid isPermaLink="true">https://community.m5stack.com/post/28505</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 14 Mar 2025 09:06:29 GMT</pubDate></item><item><title><![CDATA[Reply to How to disable M5stack fire power saving on Fri, 14 Mar 2025 07:31:43 GMT]]></title><description><![CDATA[<p dir="auto">To disable power saving on the M5Stack Fire, modify the AXP192 PMU settings using the M5Stack library in Arduino. UseM5.Power.setPowerBoostKeepOn(true); to keep power on and prevent sleep mode.  Additionally, disable deep sleep with esp_sleep_disable_wakeup_source to ensure continuous operation without unexpected shutdowns.</p>
]]></description><link>https://community.m5stack.com/post/28502</link><guid isPermaLink="true">https://community.m5stack.com/post/28502</guid><dc:creator><![CDATA[peolsolutions]]></dc:creator><pubDate>Fri, 14 Mar 2025 07:31:43 GMT</pubDate></item><item><title><![CDATA[Reply to How to disable M5stack fire power saving on Fri, 07 Mar 2025 07:29:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gbastos" aria-label="Profile: gbastos">@<bdi>gbastos</bdi></a><br />
Fire does not have power saving function</p>
]]></description><link>https://community.m5stack.com/post/28421</link><guid isPermaLink="true">https://community.m5stack.com/post/28421</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Fri, 07 Mar 2025 07:29:34 GMT</pubDate></item></channel></rss>
