<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stamp-C3 update thru pins (pinout question)]]></title><description><![CDATA[<h1>Question</h1>
<p dir="auto">Does anyone know if it is possible to upload from Arduino IDE to the Stamp-C3 using the PORT.U pins (GND, G18/D-, G19/D+, 5V) instead of using the USB-C connector? Since the ESP32-C3 does not support OTG, I assume that PORT.U and USB-C are the same, no? Otherwise, using the ESP32 Downloader Kit via the ISP pins would be the only solution if one wants to go through PCB, right? Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/7392/stamp-c3-update-thru-pins-pinout-question</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 15:35:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7392.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Mar 2025 14:49:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stamp-C3 update thru pins (pinout question) on Tue, 18 Mar 2025 03:47:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davekc" aria-label="Profile: davekc">@<bdi>davekc</bdi></a> You doubt him at your peril, Sir!</p>
]]></description><link>https://community.m5stack.com/post/28549</link><guid isPermaLink="true">https://community.m5stack.com/post/28549</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Tue, 18 Mar 2025 03:47:08 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp-C3 update thru pins (pinout question) on Mon, 17 Mar 2025 19:52:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a>,</p>
<p dir="auto">To be honest, I doubted your response, and I had to review those schematics to realize that I had missed it. Thank you so much!</p>
<p dir="auto">Regards,<br />
Dave</p>
]]></description><link>https://community.m5stack.com/post/28547</link><guid isPermaLink="true">https://community.m5stack.com/post/28547</guid><dc:creator><![CDATA[davekc]]></dc:creator><pubDate>Mon, 17 Mar 2025 19:52:34 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp-C3 update thru pins (pinout question) on Fri, 14 Mar 2025 04:25:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/davekc" aria-label="Profile: davekc">@<bdi>davekc</bdi></a></p>
<p dir="auto">M5Stamp-C3: PORT-U pins and USB-C are <strong>not</strong> the same. Check schematics <a href="https://docs.m5stack.com/en/core/stamp_c3?id=schematics" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">M5Stamp-C3<strong>U</strong>: PORT-U pins and USB-C are the same. Check schematics <a href="https://docs.m5stack.com/en/core/stamp_c3u?id=schematics" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/28499</link><guid isPermaLink="true">https://community.m5stack.com/post/28499</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 14 Mar 2025 04:25:17 GMT</pubDate></item></channel></rss>
