<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LoRa (433 old) LoRa V1.1]]></title><description><![CDATA[<p dir="auto">weiß jemand wie man ein neues V1.1 LoRa Modul so jumpert<br />
das es mit dem alten Modul kompatibel ist, der Support schweigt sich aus und hat scheinbar auch keine Ahnung</p>
]]></description><link>https://community.m5stack.com/topic/7393/lora-433-old-lora-v1-1</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:22:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7393.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Mar 2025 10:44:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LoRa (433 old) LoRa V1.1 on Wed, 09 Apr 2025 16:54:07 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/s1y99" aria-label="Profile: s1y99">@<bdi>s1y99</bdi></a></p>
<p dir="auto">ok, now I understand - thank you for clarifying about the closed source M5Core firmware.</p>
<p dir="auto">BTW: for RST and IRQ you could set no jumper and then solder a wire each to the desired GPIO on the M5Stack bus connector.</p>
]]></description><link>https://community.m5stack.com/post/28849</link><guid isPermaLink="true">https://community.m5stack.com/post/28849</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 09 Apr 2025 16:54:07 GMT</pubDate></item><item><title><![CDATA[Reply to LoRa (433 old) LoRa V1.1 on Wed, 09 Apr 2025 16:22:00 GMT]]></title><description><![CDATA[<p dir="auto">Okay, at least that's a clear statement. Then I'll convert the old modules to an SMA connector. The software is called APRSCube, by the way, and it was a good advertisement for M5Stack modules...<br />
Thank you very much.</p>
]]></description><link>https://community.m5stack.com/post/28848</link><guid isPermaLink="true">https://community.m5stack.com/post/28848</guid><dc:creator><![CDATA[s1y99]]></dc:creator><pubDate>Wed, 09 Apr 2025 16:22:00 GMT</pubDate></item><item><title><![CDATA[Reply to LoRa (433 old) LoRa V1.1 on Wed, 09 Apr 2025 15:25:37 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/s1y99" aria-label="Profile: s1y99">@<bdi>s1y99</bdi></a></p>
<p dir="auto">I am confused. Your own firmware, the one you write for your M5Core (which talks to the LoRa module), is closed source? How come? Are you not writing your own firmware?</p>
<p dir="auto">I already wrote that it is <strong>not</strong> possible to jumper LoRa V1.1 the same as the older one, please see my previous post.</p>
<p dir="auto">MOSI, MISO, SCK and CS/NSS can be setup to use the same GPIOs, however RST and IRQ <strong>cannot</strong> be jumpered to be the same.</p>
<p dir="auto">So in conclusion: If for whatever reason the firmware running on M5Core (controlling the LoRa module) <strong>cannot</strong> be modified then it is <strong>not</strong> possible to substitute the older LoRa module with the new one.</p>
]]></description><link>https://community.m5stack.com/post/28847</link><guid isPermaLink="true">https://community.m5stack.com/post/28847</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 09 Apr 2025 15:25:37 GMT</pubDate></item><item><title><![CDATA[Reply to LoRa (433 old) LoRa V1.1 on Wed, 09 Apr 2025 13:41:39 GMT]]></title><description><![CDATA[<p dir="auto">Very simple, the firmware is available as a binary file and is not open source. I'm sorry, but your answer is not helpful. How do I have to jumper the V1.1 board so that it works like the old one? I've already seen the graphics, but they're a confusing mess.</p>
]]></description><link>https://community.m5stack.com/post/28845</link><guid isPermaLink="true">https://community.m5stack.com/post/28845</guid><dc:creator><![CDATA[s1y99]]></dc:creator><pubDate>Wed, 09 Apr 2025 13:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to LoRa (433 old) LoRa V1.1 on Fri, 14 Mar 2025 11:20:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/s1y99" aria-label="Profile: s1y99">@<bdi>s1y99</bdi></a></p>
<p dir="auto">reading your other <a href="https://community.m5stack.com/topic/7368/m5stack-lora-old-lora-v1-1-kompatible?_=1741950995747">post</a>, I think you already figured that out yourself. It's not possible to jumper LoRa V1.1 so the same GPIOs are used as it were for the older LoRa module.</p>
<p dir="auto">Both LoRa modules use the same GPIOs for MOSI (23), MISO (19) and SCK (18). However RST and IRQ cannot be jumpered the same; CS/NSS can be jumpered the same.</p>
<p dir="auto">LoRa (433 old): RST(26), IRQ (36), CS/NSS (5)<br />
LoRa V1.1: RST(25/13), IRQ (35/34), CS/NSS (0, 15, 12, 5)</p>
<p dir="auto">Note: GPIO numbers above are for an M5Core (Basic).</p>
<p dir="auto">Please also see schematics <a href="https://docs.m5stack.com/en/module/lora?id=schematics" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> and <a href="https://docs.m5stack.com/en/module/Module-LoRa433_V1.1?id=schematics" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">Just curious. What is preventing you from modifying your firmware to use the GPIOs of the newer LoRa module?</p>
]]></description><link>https://community.m5stack.com/post/28509</link><guid isPermaLink="true">https://community.m5stack.com/post/28509</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 14 Mar 2025 11:20:17 GMT</pubDate></item></channel></rss>
