<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow 2 Button blocks broken]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">In UIFLow 2.0 the button blocks have recently become broken. In the drop down on the top of the block that performs an action when either button A,B or C is pressed, the option now only exists for button A:</p>
<p dir="auto"><img src="/assets/uploads/files/1741959420900-3bd3156e-7cf0-47e0-8033-540a0b5f5478-image.png" alt="3bd3156e-7cf0-47e0-8033-540a0b5f5478-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I am using the Core 2.</p>
<p dir="auto">Edit: I have seen that all other devices in UIFLow2.0 do not have buttons B or C and I have double checked to make sure the Core2 is selected and it is. This also affects all of my UIFlow2.0 projects</p>
]]></description><link>https://community.m5stack.com/topic/7395/uiflow-2-button-blocks-broken</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 12:01:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7395.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Mar 2025 13:37:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow 2 Button blocks broken on Fri, 14 Mar 2025 15:21:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ewoodier84" aria-label="Profile: ewoodier84">@<bdi>ewoodier84</bdi></a></p>
<p dir="auto">I am using chrome, I will try a cache clear. This applies both to new button blocks and existing in all projects. Any button blocks that had buttons B or C selected have reverted to button A in all of my projects.</p>
<p dir="auto">Edit: Clearing cache did not work but on another laptop I can see all three buttons, definitely some kind of local issue.</p>
]]></description><link>https://community.m5stack.com/post/28517</link><guid isPermaLink="true">https://community.m5stack.com/post/28517</guid><dc:creator><![CDATA[ewoodier84]]></dc:creator><pubDate>Fri, 14 Mar 2025 15:21:29 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 2 Button blocks broken on Fri, 14 Mar 2025 15:02:18 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ewoodier84" aria-label="Profile: ewoodier84">@<bdi>ewoodier84</bdi></a></p>
<p dir="auto">hmm, I am not seeing that. I get to select from all three buttons in UIFlow2 V2.2.3 with M5Core2 selected.</p>
<p dir="auto">The same is true when I load some of my older UIFlow2 programs.</p>
<p dir="auto">Which browser are you using? I think UIFlow2 only works properly in Chrome. Maybe try to clear the cache?</p>
]]></description><link>https://community.m5stack.com/post/28516</link><guid isPermaLink="true">https://community.m5stack.com/post/28516</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 14 Mar 2025 15:02:18 GMT</pubDate></item></channel></rss>
