<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Not able to burn UiFlow 2.0 Firmware]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
new to this and need a bit of help. I used flashed UiFlow and downloaded and ran the weather station (after fiddling with the code with syntax errors), played around with screen etc.<br />
Downloaded and ran the Core Factory Test okay too.</p>
<p dir="auto">Decided to try UiFlow2.0.<br />
Erased successfully and bound device, however, when I try config I get</p>
<p dir="auto">[Errno 2] No such file or directory: 'E:\M5Burner-v3-beta-win-x64\packages\tmp\uiflow2-cfg.bin'</p>
<p dir="auto">There is no config file saved in the Temp folder just a uiflow2.csv file.</p>
<p dir="auto">If i select burn I get a similar Java script warning and I have to kill M5Burner as its totally unresponsive.</p>
<p dir="auto"><img src="/assets/uploads/files/1742683677540-javas.png" alt="javas.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any ideas or help would be appreciated.</p>
]]></description><link>https://community.m5stack.com/topic/7421/not-able-to-burn-uiflow-2-0-firmware</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 14:31:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7421.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Mar 2025 22:49:26 GMT</pubDate><ttl>60</ttl></channel></rss>
