<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Connect IMU Int pin to the esp]]></title><description><![CDATA[<p dir="auto">Hi!<br />
Is it possible to disassemble &amp; connect IMU INT pin to some GPIO?<br />
I'd like to add Wake On Motion to the stick and it looks like IMU supports that (checked StickCPlus libs).<br />
Idk why StickCPlus2 doesn't have int pin connected</p>
]]></description><link>https://community.m5stack.com/topic/7425/connect-imu-int-pin-to-the-esp</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 04:15:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7425.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 23 Mar 2025 18:02:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Connect IMU Int pin to the esp on Mon, 24 Mar 2025 10:20:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/xxx_yyy" aria-label="Profile: xxx_yyy">@<bdi>xxx_yyy</bdi></a></p>
<p dir="auto">I stand corrected. My apologies. You are absolutely correct: IMU INT in M5StickCPlus2 is not connected to anything. (I was looking at the RTC INT.)</p>
<p dir="auto">That said - and to answer your original question - yes, it is possible to connect the IMU INT pin to an ESP32 GPIO. Please see <a href="https://www.gwendesign.ch/kb/m5stack/m5stickcplus2/#wake-on-motion" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">However it would only allow to wake ESP32 from deep/light sleep, but not to turn M5StickCPlus2 back on from being powered off due to the fact that IMU is powered from 3.3 V (and not like RTC from VBAT_IN).</p>
]]></description><link>https://community.m5stack.com/post/28626</link><guid isPermaLink="true">https://community.m5stack.com/post/28626</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 24 Mar 2025 10:20:17 GMT</pubDate></item><item><title><![CDATA[Reply to Connect IMU Int pin to the esp on Mon, 24 Mar 2025 08:16:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> According to the scheme INT is not connected to anything <a href="https://m5stack-doc.oss-cn-shenzhen.aliyuncs.com/512/Sch_M5StickC_Plus2_sch_03.png" target="_blank" rel="noopener noreferrer nofollow ugc">link text</a></p>
]]></description><link>https://community.m5stack.com/post/28622</link><guid isPermaLink="true">https://community.m5stack.com/post/28622</guid><dc:creator><![CDATA[xxx_yyy]]></dc:creator><pubDate>Mon, 24 Mar 2025 08:16:45 GMT</pubDate></item><item><title><![CDATA[Reply to Connect IMU Int pin to the esp on Sun, 23 Mar 2025 20:05:16 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/xxx_yyy" aria-label="Profile: xxx_yyy">@<bdi>xxx_yyy</bdi></a></p>
<p dir="auto">IMU in M5StickCPlus2 is running from the battery and IMU INT is connected to the power on logic. So it should be possible to setup WoM, then turn ESP32 off and then upon motion IMU INT turns ESP32 back on again.</p>
]]></description><link>https://community.m5stack.com/post/28616</link><guid isPermaLink="true">https://community.m5stack.com/post/28616</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 23 Mar 2025 20:05:16 GMT</pubDate></item></channel></rss>
