<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow2 burn fails on m5burner 3.0.0]]></title><description><![CDATA[<p dir="auto">Burn of UIFlow2 (v2.2.4-16MB) to M5Core-Grey  using M5Burner loads stub but not full firmware.  Burn of UIFlow_M5GO (same M5Burner) works fine.  The UIFlow2 burn results in inoperable M5GO even though final message says 'Burn Successfully, click here to return'.</p>
<p dir="auto">Here is screen shot of output from Burn:</p>
<p dir="auto">--chip auto --port /dev/tty.usbserial-01DB92E6 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x9000 /Applications/M5Burner.app/Contents/Resources/packages/tmp/uiflow2-cfg.bin<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v4.7-dev<br />
Serial port /dev/tty.usbserial-01DB92E6<br />
Connecting...<br />
.</p>
<p dir="auto">Detecting chip type... Unsupported detection protocol, switching and trying again...<br />
Connecting...<br />
.</p>
<p dir="auto">Detecting chip type...<br />
ESP32<br />
Chip is ESP32-D0WDQ6 (revision v1.0)<br />
Crystal is 40MHz<br />
MAC: 98:f4:ab:6c:dc:00<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Changing baud rate to 1500000<br />
Changed.<br />
Auto-detected Flash size: 16MB<br />
Flash will be erased from 0x00009000 to 0x0000efff...<br />
Compressed 24576 bytes to 475...<br />
Writing at 0x00009000... (100 %)<br />
Wrote 24576 bytes (475 compressed) at 0x00009000 in 0.2 seconds (effective 1153.6 kbit/s)...<br />
Hash of data verified.</p>
<p dir="auto">Leaving...<br />
Hard resetting via RTS pin...</p>
]]></description><link>https://community.m5stack.com/topic/7432/uiflow2-burn-fails-on-m5burner-3-0-0</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:05:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7432.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Mar 2025 16:32:10 GMT</pubDate><ttl>60</ttl></channel></rss>
