<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Library for 6-DoF IMU Pro Mini Unit]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I been trying to find a library that will work with the <a href="https://shop.m5stack.com/products/6-dof-imu-pro-mini-unit-bmi270-bmm150-bmp280?variant=44148562690305" target="_blank" rel="noopener noreferrer nofollow ugc">M5-stack 6-DoF IMU Pro Mini Unit (BMI270, BMM150, BMP280)</a>for an ESP-32 running micro python and preferable using i2c communication however are open to other types.<br />
Does any one have any ideas?</p>
]]></description><link>https://community.m5stack.com/topic/7441/library-for-6-dof-imu-pro-mini-unit</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:55:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7441.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Mar 2025 11:35:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Library for 6-DoF IMU Pro Mini Unit on Tue, 13 Jan 2026 21:19:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/007jimmey" aria-label="Profile: 007jimmey">@<bdi>007jimmey</bdi></a><br />
A bit late to the party here but.. maybe of help to you or others</p>
<p dir="auto">The <code>bmp280</code> temperature/humidity/pressure sensor is well known, there are lots of libraries for this (I2C) eg: <a href="https://github.com/robert-hh/BME280" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/robert-hh/BME280</a></p>
<li>it has it's own I2C address and is separate from the bmi270/bmm150</li>
<p dir="auto">The <code>bmi270</code> six axis sensor (acceleration and gyro) has a basic, large and slow driver here: <a href="https://github.com/micropython/micropython-lib/tree/master/micropython/drivers/imu/bmi270" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/micropython/micropython-lib/tree/master/micropython/drivers/imu/bmi270</a></p>
<p dir="auto">I have my own pair of drivers for this:<br />
<a href="https://codeberg.org/easytarget/bmi270-micropython" target="_blank" rel="noopener noreferrer nofollow ugc">https://codeberg.org/easytarget/bmi270-micropython</a></p>
<li><code>bmi270_fast.py</code> is a drop-in replacement for the above driver, but is 5x smaller, and 25x faster loading. (92 ms vs 2.3 seconds..)</li>
<li><code>bmi270_legacy.py</code> is a <em>work in progress</em> full-feature driver I'm working on for my Tab5. It uses for the 'legacy config' (tablet/mobile phone featureset) and has motion and orientation sensors and interrupts available.</li>
<p dir="auto">But.. the <code>BMM150</code> magnetometer is an issue, it is attached to the 'auxillary' bus of the BMI270, not to the main I2C bus. You can only to access it via special features in the BMI270, and none of the MicroPython drivers support it.</p>
]]></description><link>https://community.m5stack.com/post/30453</link><guid isPermaLink="true">https://community.m5stack.com/post/30453</guid><dc:creator><![CDATA[easytarget]]></dc:creator><pubDate>Tue, 13 Jan 2026 21:19:03 GMT</pubDate></item></channel></rss>
