<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MIDI Synth Unit with DIN &amp; TRS connectors (SAM2695)]]></title><description><![CDATA[<p dir="auto">This unit works great using UiFlow and the Grove UART connection.   I have been unable to get the synth to respond to MIDI input from an Arturia MINILAB 3 via either the MIDI IN or TRS IN connector.  The  MIDI signals coming from the MINILAB and going in to either of these two connectors are correct and verified with a logic analyzer.</p>
<p dir="auto">I am new to MIDI - am I making a beginners mistake or is it not possible to send a MIDI note in to this device from a keyboard?</p>
]]></description><link>https://community.m5stack.com/topic/7458/midi-synth-unit-with-din-trs-connectors-sam2695</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:31:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7458.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Mar 2025 21:18:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MIDI Synth Unit with DIN &amp; TRS connectors (SAM2695) on Tue, 01 Apr 2025 20:03:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/holofloh" aria-label="Profile: holofloh">@<bdi>holofloh</bdi></a></p>
<p dir="auto">Connecting TXD to RXD &amp; supplying 5V to the Grove connector works great!  I never thought about studying the schematic right on the device.  Thanks for your assistance!</p>
]]></description><link>https://community.m5stack.com/post/28755</link><guid isPermaLink="true">https://community.m5stack.com/post/28755</guid><dc:creator><![CDATA[earla]]></dc:creator><pubDate>Tue, 01 Apr 2025 20:03:48 GMT</pubDate></item><item><title><![CDATA[Reply to MIDI Synth Unit with DIN &amp; TRS connectors (SAM2695) on Tue, 01 Apr 2025 16:05:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/holofloh" aria-label="Profile: holofloh">@<bdi>holofloh</bdi></a></p>
<p dir="auto">Very helpful.  Thank you so much!</p>
]]></description><link>https://community.m5stack.com/post/28752</link><guid isPermaLink="true">https://community.m5stack.com/post/28752</guid><dc:creator><![CDATA[earla]]></dc:creator><pubDate>Tue, 01 Apr 2025 16:05:35 GMT</pubDate></item><item><title><![CDATA[Reply to MIDI Synth Unit with DIN &amp; TRS connectors (SAM2695) on Tue, 01 Apr 2025 05:52:11 GMT]]></title><description><![CDATA[<p dir="auto">When looking to the schematic on the back side of the unit then you will see the signal paths:</p>
<li>from MIDI IN to Groove TXD and the Switch</li>
<li>from Grove RXD to SAM2695 and the Switch</li>
<li>from the Switch to MIDI OUT</li>
<p dir="auto">Connecting the MIDI IN direct to the SAM2695 is not prepared.</p>
<p dir="auto">You have to go thru Groove port to do that. It may work if you just bridge the TXD and RXT on the port with a jumper wire (don't forget the 5V supply). Otherwise you have to go thru your processor and put everything what is coming in direct to the out.</p>
]]></description><link>https://community.m5stack.com/post/28733</link><guid isPermaLink="true">https://community.m5stack.com/post/28733</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Tue, 01 Apr 2025 05:52:11 GMT</pubDate></item></channel></rss>
