<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tailbat problem: black connector ph2.0-4p]]></title><description><![CDATA[<p dir="auto">I have a tailbat and the black connector fell apart.I cannot refix it on the contacts of the pcb; was it glued? Soldered? What can I do?</p>
]]></description><link>https://community.m5stack.com/topic/7474/tailbat-problem-black-connector-ph2-0-4p</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 04:15:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7474.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Apr 2025 18:39:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tailbat problem: black connector ph2.0-4p on Sun, 06 Apr 2025 08:20:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lebagh" aria-label="Profile: LeBagh">@<bdi>LeBagh</bdi></a> No, the housing clips over the contacts and is held to the PCB only by the contact pins.<br />
It is not a normal header but it is a 2.0mm header not a 2.96mm header</p>
]]></description><link>https://community.m5stack.com/post/28813</link><guid isPermaLink="true">https://community.m5stack.com/post/28813</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 06 Apr 2025 08:20:01 GMT</pubDate></item></channel></rss>
