<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Running ENV III Hat and SGP30 Unit Simultaneously on M5StickC Plus2]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I'm working on a project using the M5StickC Plus2, and I need some guidance on sensor compatibility and I2C addressing.</p>
<p dir="auto">Currently, I have the following hardware:</p>
<p dir="auto">M5StickC Plus2<br />
ENV III Hat (connected via the Hat port)<br />
SGP30 Unit (connected via the Unit port)<br />
I would like to run both the ENV III Hat and the SGP30 Unit at the same time. Before I dive deep into development, I want to confirm:</p>
<li>Is it possible to have both devices connected and operational simultaneously on the M5StickC Plus2?</li>
<li>Are there any I2C address conflicts between these two sensors?</li>
<li>If there is a conflict, is there a recommended workaround (e.g., using an I2C hub, bit-banging, or switching to an ENV II Hat instead)?</li>
<p dir="auto">For reference, I’ve attached screenshots of the Hat and Unit details as shown in the M5Stack documentation.</p>
<p dir="auto"><img src="/assets/uploads/files/1743893903790-hat.jpg" alt="Hat.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1743893912178-unit.jpg" alt="Unit.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any help or insights would be greatly appreciated.</p>
]]></description><link>https://community.m5stack.com/topic/7475/running-env-iii-hat-and-sgp30-unit-simultaneously-on-m5stickc-plus2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:28:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7475.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Apr 2025 22:58:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Running ENV III Hat and SGP30 Unit Simultaneously on M5StickC Plus2 on Sat, 05 Apr 2025 23:12:07 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1743894726696-uiflow.jpg" alt="UIFlow.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/28811</link><guid isPermaLink="true">https://community.m5stack.com/post/28811</guid><dc:creator><![CDATA[shiva]]></dc:creator><pubDate>Sat, 05 Apr 2025 23:12:07 GMT</pubDate></item></channel></rss>
