<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CoreS3 and Goplus2]]></title><description><![CDATA[<p dir="auto">Hello!<br />
I have a CoreS3 and want to know if it is compatible with the Goplus2 Module for controlling servos and dc motors.<br />
Must i remove the battery?<br />
Greetings,<br />
Paul</p>
]]></description><link>https://community.m5stack.com/topic/7476/cores3-and-goplus2</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 12:30:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7476.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 06 Apr 2025 14:28:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CoreS3 and Goplus2 on Thu, 10 Apr 2025 05:56:50 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/rammelsberg" aria-label="Profile: rammelsberg">@<bdi>rammelsberg</bdi></a></p>
<p dir="auto">I don't see solder jumpers and I cannot find the source code for the firmware running in M5GoPlus2 so no, I don't think you can easily modify the I2C address.</p>
]]></description><link>https://community.m5stack.com/post/28855</link><guid isPermaLink="true">https://community.m5stack.com/post/28855</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 10 Apr 2025 05:56:50 GMT</pubDate></item><item><title><![CDATA[Reply to CoreS3 and Goplus2 on Sun, 06 Apr 2025 18:40:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi Felix!<br />
Thanks for your response!<br />
That's a pity though. I already have the modules here but did not try to connect. Does the goplus2 have any solder jumpers for modifying the address or is it hard coded?<br />
Or maybe it will run with my old m5stack gray...</p>
<p dir="auto">Greetings,<br />
Paul</p>
]]></description><link>https://community.m5stack.com/post/28817</link><guid isPermaLink="true">https://community.m5stack.com/post/28817</guid><dc:creator><![CDATA[rammelsberg]]></dc:creator><pubDate>Sun, 06 Apr 2025 18:40:12 GMT</pubDate></item><item><title><![CDATA[Reply to CoreS3 and Goplus2 on Sun, 06 Apr 2025 18:08:02 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/rammelsberg" aria-label="Profile: rammelsberg">@<bdi>rammelsberg</bdi></a></p>
<p dir="auto">well, there is an I2C address conflict between M5CoreS3 Touch and M5GoPlus2 as both use I2C address 0x38.</p>
<p dir="auto">Interestingly when I use M5CoreS3 with M5GoPlus2 in UIFlow2 I can control a servo and use the touch screen. However this is only true for servo 1,2 and 4. When I try to use servo 3 the system locks up.</p>
<p dir="auto">Note: I have not tried to control DC motors.</p>
<p dir="auto">So I'd expect some issues and do not recommend to use M5GoPlus2 with M5CoreS3.</p>
]]></description><link>https://community.m5stack.com/post/28815</link><guid isPermaLink="true">https://community.m5stack.com/post/28815</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 06 Apr 2025 18:08:02 GMT</pubDate></item></channel></rss>
