<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PAHub revival]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/6912/pa-hub">Pa hub</a><br />
Hi there,<br />
Just revisiting the PA Hub  story. I felt like breeing cheated by M5Stack because It is far from reaching the promisses.<br />
For me the problem is the tutorial videos showing something when you try to reproduce this is not working.<br />
look at M5Stack PAhub Unit - Connecting multiple i2c Devices.<br />
Luke is choosing the TOF sensors only and magically the Pa Hub port are there. but by which magic? after adding some labels... but why?<br />
I tried it there <a href="https://flow.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://flow.m5stack.com/</a><br />
Old address still working though.</p>
]]></description><link>https://community.m5stack.com/topic/7490/pahub-revival</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:04:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7490.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Apr 2025 07:54:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PAHub revival on Sun, 13 Apr 2025 11:58:07 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dr_froggy_rd" aria-label="Profile: DR_Froggy_rD">@<bdi>DR_Froggy_rD</bdi></a></p>
<p dir="auto">I am afraid that doesn't work. A PaHub is for i2<strong>C</strong> devices (red Grove connector); the PDM unit is an I2<strong>S</strong> device (white Grove connector).</p>
<p dir="auto">BTW: that is the reason in UIFlow2 PaHub doesn't show as option when the PDM unit selected.</p>
]]></description><link>https://community.m5stack.com/post/28877</link><guid isPermaLink="true">https://community.m5stack.com/post/28877</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 13 Apr 2025 11:58:07 GMT</pubDate></item><item><title><![CDATA[Reply to PAHub revival on Sun, 13 Apr 2025 08:18:32 GMT]]></title><description><![CDATA[<p dir="auto">if anyone can help me there: how can I get Multiple Pdm unit being connected with a hub to a atom s3?</p>
]]></description><link>https://community.m5stack.com/post/28876</link><guid isPermaLink="true">https://community.m5stack.com/post/28876</guid><dc:creator><![CDATA[DR_Froggy_rD]]></dc:creator><pubDate>Sun, 13 Apr 2025 08:18:32 GMT</pubDate></item><item><title><![CDATA[Reply to PAHub revival on Sat, 12 Apr 2025 08:24:34 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1744446221311-361710f2-5ef4-435d-8400-a4457ed0889e-grafik.png" alt="361710f2-5ef4-435d-8400-a4457ed0889e-grafik.png" class=" img-fluid img-markdown" /><br />
It is what I meant you cannot choose PA. HUB_0 as  Port for the second PAHUB</p>
]]></description><link>https://community.m5stack.com/post/28871</link><guid isPermaLink="true">https://community.m5stack.com/post/28871</guid><dc:creator><![CDATA[DR_Froggy_rD]]></dc:creator><pubDate>Sat, 12 Apr 2025 08:24:34 GMT</pubDate></item><item><title><![CDATA[Reply to PAHub revival on Sat, 12 Apr 2025 08:21:29 GMT]]></title><description><![CDATA[<p dir="auto">So I have an apology to do. It was probably not working because I was trying with a PDM when I tried with a TOF it worked... somehow.<br />
However when trying to put a second Pahub in daisy chaiin It is not so I believe doing it first in blockly then in Python copying modifying should work. But when adding a second Pa Hub as Pa HUB 1you cannot choose PaHUB_1 / channel _0 to 5.</p>
]]></description><link>https://community.m5stack.com/post/28870</link><guid isPermaLink="true">https://community.m5stack.com/post/28870</guid><dc:creator><![CDATA[DR_Froggy_rD]]></dc:creator><pubDate>Sat, 12 Apr 2025 08:21:29 GMT</pubDate></item></channel></rss>
