<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fix problem]]></title><description><![CDATA[<p dir="auto">I flashed UIFlow2.0 on cardputer and now it doesn't want to install other firmware, now it works only with <a href="https://uiflow2.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://uiflow2.m5stack.com/</a><br />
How can I fix it?</p>
]]></description><link>https://community.m5stack.com/topic/7506/fix-problem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 02:31:13 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7506.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Apr 2025 18:34:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fix problem on Fri, 18 Apr 2025 11:12:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niktoi" aria-label="Profile: NiktoI">@<bdi>NiktoI</bdi></a> you need to use m5burner to erase the firmware to burn new firmware.<br />
You also need to put the cardputer into firmware mode.</p>
]]></description><link>https://community.m5stack.com/post/28928</link><guid isPermaLink="true">https://community.m5stack.com/post/28928</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 18 Apr 2025 11:12:18 GMT</pubDate></item></channel></rss>
