<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[EZData2 unable to POST to?]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Here is what I am testing:</p>
<p dir="auto">Sending data in a POST call to Ezdata.</p>
<p dir="auto">I've set up my data key in EzData and can successfully use the url given on the share button.</p>
<p dir="auto"><a href="https://ezdata2.m5stack.com/api/v2/..token../data" target="_blank" rel="noopener noreferrer nofollow ugc">https://ezdata2.m5stack.com/api/v2/..token../data</a></p>
<p dir="auto">However I cannot find the correct url to POST data?</p>
<p dir="auto">curl -X POST <a href="https://ezdata2.m5stack.com/api/v2/store/%5Btoken%5D/HA_climate" target="_blank" rel="noopener noreferrer nofollow ugc">https://ezdata2.m5stack.com/api/v2/store/[token]/HA_climate</a> <br />
-H "Content-Type: application/json" <br />
-d '{"value": "Test from curl"}'<br />
{"timestamp":"2025-04-24T23:05:34.037+00:00","status":404,"error":"Not Found","path":"/api/v2/store/[token]/HA_climate"}%</p>
<p dir="auto">I have also tried "v2/entry/", "v2/input/"</p>
<p dir="auto">It would be great if I could send data using the API into Ezdata so I can use blocky to design apps to use that data.</p>
<p dir="auto">Any help appreciated. Cheers.</p>
]]></description><link>https://community.m5stack.com/topic/7521/ezdata2-unable-to-post-to</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 09:14:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7521.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Apr 2025 23:33:41 GMT</pubDate><ttl>60</ttl></channel></rss>
