<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atomic Echo Base+S3R  Voice Assistant problem]]></title><description><![CDATA[<p dir="auto">Hello, i load the Atomic Echo Base OpenAI Voice Assistant with m5burner to AtomS3R and Atomic Echo Base, docs there: <a href="https://docs.m5stack.com/en/guide/realtime/openai/atomic_echo_base" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/guide/realtime/openai/atomic_echo_base</a> , problem is maybe the mic which is suggested by a user in the m5burner, the openai logo appears, but nothing happens next, how can I fix this problem?, Is there any program to test the mic on the atoms3r+echo base platform?</p>
]]></description><link>https://community.m5stack.com/topic/7549/atomic-echo-base-s3r-voice-assistant-problem</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 16:19:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7549.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 May 2025 20:00:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Atomic Echo Base+S3R  Voice Assistant problem on Wed, 14 May 2025 03:58:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdseldon" aria-label="Profile: mdseldon">@<bdi>mdseldon</bdi></a><br />
are you able to access the serial log?</p>
]]></description><link>https://community.m5stack.com/post/29051</link><guid isPermaLink="true">https://community.m5stack.com/post/29051</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Wed, 14 May 2025 03:58:29 GMT</pubDate></item></channel></rss>
