<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Board Manager 2.1.4 Failure in Arduino 1.8.19 IDE]]></title><description><![CDATA[<p dir="auto">M5Unfied version 0.2.7 installed. Do I need to use IDE 2 now? Trying to compile for PaperS3.</p>
<p dir="auto">Workedaround by commenting out all references to M5StamPLC and M5Tab5 (some are bypassed by #ifdefs and don't have to be deleted):</p>
<pre><code>Arduino: 1.8.19 (Linux), Board: "M5PaperS3, Disabled, OPI PSRAM, QIO 80MHz, 16MB (128Mb), Core 1, Core 1, Hardware CDC and JTAG, Enabled, Disabled, Disabled, UART0 / Hardware CDC, 16M Flash (3MB APP/9.9MB FATFS), 240MHz (WiFi), 921600, None, Disabled"
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:83:12: error: 'board_M5StampPLC' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'}
 { board_t::board_M5StampPLC   , GPIO_NUM_15,GPIO_NUM_13 , GPIO_NUM_1 ,GPIO_NUM_2  },
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:148:12: error: 'board_M5StampPLC' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'}
 { board_t::board_M5StampPLC   , GPIO_NUM_7,  GPIO_NUM_8,  GPIO_NUM_9,  GPIO_NUM_10 },
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:167:12: error: 'board_M5StampPLC' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'}
 { board_t::board_M5StampPLC   , GPIO_NUM_21 },
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp: In member function 'void m5::M5Unified::_begin(const m5::M5Unified::config_t&amp;)':
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:1237:19: error: 'board_M5StampPLC' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'}
     case board_t::board_M5StampPLC:
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp: In member function 'void m5::M5Unified::_begin_spk(m5::M5Unified::config_t&amp;)':
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:1554:21: error: 'board_M5StampPLC' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'}
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp: In member function 'virtual void m5::M5Unified::update()':
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:1821:21: error: 'board_M5Tab5' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'}
       case board_t::board_M5Tab5:
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:1953:19: error: 'board_M5StampPLC' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'}
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp: In member function 'void m5::M5Unified::setTouchButtonHeightByRatio(uint8_t)':
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:2044:19: error: 'board_M5Tab5' is not a member of 'm5::board_t' {aka 'lgfx::boards::board_t'}
exit status 1
Error compiling for board M5PaperS3.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -&gt; Preferences.
]]></description><link>https://community.m5stack.com/topic/7565/board-manager-2-1-4-failure-in-arduino-1-8-19-ide</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:42:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7565.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 May 2025 21:02:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Board Manager 2.1.4 Failure in Arduino 1.8.19 IDE on Wed, 21 May 2025 16:10:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kuriko" aria-label="Profile: kuriko">@<bdi>kuriko</bdi></a> I believe so, but now that I've patched M5Unified, I'd need to unpatch and test again. I'll report back if anything further happens.</p>
]]></description><link>https://community.m5stack.com/post/29080</link><guid isPermaLink="true">https://community.m5stack.com/post/29080</guid><dc:creator><![CDATA[wsanders]]></dc:creator><pubDate>Wed, 21 May 2025 16:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to Board Manager 2.1.4 Failure in Arduino 1.8.19 IDE on Wed, 21 May 2025 01:21:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wsanders" aria-label="Profile: wsanders">@<bdi>wsanders</bdi></a><br />
looks like some kind of version problem, have you upgraded all libraries to the newest version?</p>
]]></description><link>https://community.m5stack.com/post/29079</link><guid isPermaLink="true">https://community.m5stack.com/post/29079</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Wed, 21 May 2025 01:21:12 GMT</pubDate></item></channel></rss>
