<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[issue with CORE2 library]]></title><description><![CDATA[<p dir="auto">Hi All,<br />
My M5Core2 library fails compiling with<br />
pngle.c:31:10: fatal error: rom/miniz.h: No such file or directory<br />
31 | #include &lt;rom/miniz.h&gt;<br />
|          ^~~~~~~~~~~~~<br />
compilation terminated.</p>
<p dir="auto">Using 2.3.6 arduino ide and latest library (both with M5Stck and ESP Board jsons). I had blank code with just the library and it failed.<br />
thanks</p>
]]></description><link>https://community.m5stack.com/topic/7569/issue-with-core2-library</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:42:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7569.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 May 2025 19:32:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to issue with CORE2 library on Sun, 17 Aug 2025 17:54:34 GMT]]></title><description><![CDATA[<p dir="auto">The Problem seems to still persist. Had the same issue and solved it this way.<br />
Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/dan-perren" aria-label="Profile: Dan-Perren">@<bdi>Dan-Perren</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> for the solution!</p>
]]></description><link>https://community.m5stack.com/post/29773</link><guid isPermaLink="true">https://community.m5stack.com/post/29773</guid><dc:creator><![CDATA[raeph]]></dc:creator><pubDate>Sun, 17 Aug 2025 17:54:34 GMT</pubDate></item><item><title><![CDATA[Reply to issue with CORE2 library on Sun, 25 May 2025 16:11:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/expatnoha" aria-label="Profile: ExpatNoHa">@<bdi>ExpatNoHa</bdi></a> I sent an email to M5Stack Support!</p>
]]></description><link>https://community.m5stack.com/post/29106</link><guid isPermaLink="true">https://community.m5stack.com/post/29106</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sun, 25 May 2025 16:11:27 GMT</pubDate></item><item><title><![CDATA[Reply to issue with CORE2 library on Sat, 24 May 2025 02:47:05 GMT]]></title><description><![CDATA[<p dir="auto">Reverting to 2.14 worked for me.</p>
]]></description><link>https://community.m5stack.com/post/29101</link><guid isPermaLink="true">https://community.m5stack.com/post/29101</guid><dc:creator><![CDATA[ExpatNoHa]]></dc:creator><pubDate>Sat, 24 May 2025 02:47:05 GMT</pubDate></item><item><title><![CDATA[Reply to issue with CORE2 library on Fri, 23 May 2025 18:51:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dan-perren" aria-label="Profile: Dan-Perren">@<bdi>Dan-Perren</bdi></a>  Me too!</p>
<p dir="auto">After 'letting' Arduino IDE update a bunch of boards and libraries...<br />
It started to happen.<br />
fatal error: rom/miniz.h: No such file or directory</p>
<p dir="auto">Best fix was revert to M5Stack boards to ver 2.14<br />
(3.20 was the problem.)<br />
cheers</p>
]]></description><link>https://community.m5stack.com/post/29099</link><guid isPermaLink="true">https://community.m5stack.com/post/29099</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Fri, 23 May 2025 18:51:21 GMT</pubDate></item><item><title><![CDATA[Reply to issue with CORE2 library on Fri, 23 May 2025 04:56:46 GMT]]></title><description><![CDATA[<p dir="auto">I was experiencing the same issue and through trial and error I resolved it for me by removing the version 3.20 M5Stack board, quitting the Arduino IDE and deleting the username/Library/Arduino15 folder. I then restarted the IDE and installed the version 2.1.4 M5Stack board.</p>
<p dir="auto">I then uninstalled the M5Stack library version 0.4.6 and reinstalled it. Has worked successfully on two silicon based Macs. (MacBook Pro M1 and MacStudio)</p>
]]></description><link>https://community.m5stack.com/post/29092</link><guid isPermaLink="true">https://community.m5stack.com/post/29092</guid><dc:creator><![CDATA[Dan Perren]]></dc:creator><pubDate>Fri, 23 May 2025 04:56:46 GMT</pubDate></item><item><title><![CDATA[Reply to issue with CORE2 library on Thu, 22 May 2025 12:55:21 GMT]]></title><description><![CDATA[<p dir="auto">I have the (almost) identical problem:</p>
<p dir="auto">pngle.c:34:10: fatal error: rom/miniz.h: No such file or directory<br />
34 | #include &lt;rom/miniz.h&gt;<br />
|          ^~~~~~~~~~~~~<br />
<p dir="auto">Arduino IDE 2.3.6 + Paper S3<br />
testing drawImageData.ino example<br />
<a href="https://github.com/m5stack/M5EPD/blob/main/examples/Basics/DISPLAY_URL_JPG/DISPLAY_URL_JPG.ino" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5EPD/blob/main/examples/Basics/DISPLAY_URL_JPG/DISPLAY_URL_JPG.ino</a></p>
]]></description><link>https://community.m5stack.com/post/29090</link><guid isPermaLink="true">https://community.m5stack.com/post/29090</guid><dc:creator><![CDATA[nomuza]]></dc:creator><pubDate>Thu, 22 May 2025 12:55:21 GMT</pubDate></item></channel></rss>
