<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Strange program running in after installing UIflow2 on factory set new AtomS3 Lite]]></title><description><![CDATA[<p dir="auto">Moved from General</p>
<p dir="auto">Experienced a strange event while using my ATOM S3 Lite for the first time.</p>
<p dir="auto">MacOS</p>
<p dir="auto">M5Burner was already running when I attached the device.<br />
Downloaded the latest uiflow2 dated 29-05-2025<br />
Configured, and started burn, which ran quickly, without the usual bind request.<br />
Started a new project.<br />
Connected, but was unable to Run or Load.<br />
Process running in terminal installed itself as something suggesting a BT Beacon, and established<br />
a WiFi AP on a 192.168.4.1 IP. It also appeared to be transferring data.</p>
<p dir="auto">Unfortunately I don't have a copy of the output.</p>
<p dir="auto">I restarted M5 Burner, and a new update from the same date was available. Burning this version solved the problem.</p>
<p dir="auto">Does anyone know what happened here?</p>
]]></description><link>https://community.m5stack.com/topic/7592/strange-program-running-in-after-installing-uiflow2-on-factory-set-new-atoms3-lite</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:02:13 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7592.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Jun 2025 10:58:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Strange program running in after installing UIflow2 on factory set new AtomS3 Lite on Sun, 01 Jun 2025 20:57:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> There was no previous firmware that I installed. This was an out-of-the-box installation. I downloaded the latest update - I think 2.2.7 - and that's when the problem occurred.<br />
Also, when I went to press burn, there was no opportunity to erase before burning.</p>
]]></description><link>https://community.m5stack.com/post/29155</link><guid isPermaLink="true">https://community.m5stack.com/post/29155</guid><dc:creator><![CDATA[Boomvalt]]></dc:creator><pubDate>Sun, 01 Jun 2025 20:57:55 GMT</pubDate></item><item><title><![CDATA[Reply to Strange program running in after installing UIflow2 on factory set new AtomS3 Lite on Sun, 01 Jun 2025 17:50:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boomvalt" aria-label="Profile: Boomvalt">@<bdi>Boomvalt</bdi></a> No must always erase first to remove the previous firmware and config.<br />
Once the erase process is done then you will be asked to bind (you may need to erase the old Atom3 from UIFLOW2 account first) then you can burn a clean update.</p>
]]></description><link>https://community.m5stack.com/post/29153</link><guid isPermaLink="true">https://community.m5stack.com/post/29153</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 01 Jun 2025 17:50:55 GMT</pubDate></item></channel></rss>
