<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[timescamps of the photos taken by V-training]]></title><description><![CDATA[<p dir="auto">When I take photos with V-traning, all the timestamps on the photos are set to 2075. How can I fix this?</p>
]]></description><link>https://community.m5stack.com/topic/7636/timescamps-of-the-photos-taken-by-v-training</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:23:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7636.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Jun 2025 08:25:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to timescamps of the photos taken by V-training on Wed, 25 Jun 2025 01:13:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/naofuruta" aria-label="Profile: naofuruta">@<bdi>naofuruta</bdi></a> The issue with the timestamp being set to 2075 on photos taken with V-Training is likely due to a firmware or configuration problem. Here’s how you can fix it:<br />
Steps to Resolve:</p>
<p dir="auto">Update Firmware:</p>
<p dir="auto">Ensure your M5StickV or the device running V-Training has the latest firmware installed. Outdated firmware can cause incorrect timestamps.<br />
Download the latest firmware from the M5Stack official website.</p>
<p dir="auto">Check RTC (Real-Time Clock):</p>
<p dir="auto">The device’s RTC might not be properly set. Use the following steps to sync the time:<br />
Connect the device to Wi-Fi (if supported) to sync the time automatically.<br />
Manually set the RTC using the device’s configuration menu or via a script.</p>
<p dir="auto">Reconfigure V-Training:</p>
<p dir="auto">Reset the V-Training application settings to default and reconfigure it.<br />
Ensure the timestamp settings in the app are correctly configured.</p>
<p dir="auto">Verify SD Card:</p>
<p dir="auto">A corrupted or improperly formatted SD card can cause timestamp issues. Format the SD card to FAT32 and try again.</p>
<p dir="auto">Factory Reset:</p>
<p dir="auto">If the issue persists, perform a factory reset on the device and reinstall the firmware and V-Training application.</p>
<p dir="auto">Additional Notes:</p>
<p dir="auto">If the problem continues, contact <a href="mailto:support@m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">support@m5stack.com</a> for further assistance.<br />
Provide details such as the device model, firmware version, and steps you’ve already tried.<br />
<a href="https://chat.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://chat.m5stack.com/</a></p>
]]></description><link>https://community.m5stack.com/post/29326</link><guid isPermaLink="true">https://community.m5stack.com/post/29326</guid><dc:creator><![CDATA[yuyun2000]]></dc:creator><pubDate>Wed, 25 Jun 2025 01:13:18 GMT</pubDate></item></channel></rss>
