<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Program upload error stickC plus2]]></title><description><![CDATA[<p dir="auto">Hello,<br />
Firstly, my apologies, although willing to learn I am completely ignorant of the complexities involved to something that I thought would be easy to use without needing any intermediate understanding of programming.</p>
<p dir="auto">And so with my Luddism exposed I now ask for someone to pity me and help resolve my problem, please.</p>
<p dir="auto">I bought a stickC Plus2 and the soil moisture with pump unit.<br />
I followed the instructions and also built the watering program as on the demonstration video at the bottom of the units webpage<br />
In UIflow2 and saved it to the cloud.<br />
After downloading and installing the software for the m5 burner and specified driver, I found that it will not work on my mac. I have no hub to connect through either so I can not try that option.<br />
So I used my father’s windows laptop, completed the same procedure and successfully burned the UIflow2 software to the stickC plus2.<br />
I get a nice warm feeling when I do something that I deem as clever and outside of my wheelhouse… yay me!</p>
<p dir="auto">Now my problem seems to arrive when I attempt to send the watering program made on blockly, to the stick.<br />
I get the following message on the terminal popup and also on the stick2.</p>
<p dir="auto">I have googled sections of the script but it returns nothing that I recognise, or make any sense of.<br />
Could someone possibly help me?</p>
<p dir="auto">TIA</p>
<p dir="auto">Web Terminal •<br />
Row<br />
24<br />
Col<br />
94<br />
apped Pa Serial Rors!<br />
(510560) i2c: i2c driver install error<br />
E<br />
E<br />
(510602) transport_base: tep_read error, errno-Software caused connection abort<br />
(510602) ngtt_client: esp_mgtt_handle_transport_read_error: transport_read() error: errno=11<br />
3<br />
E<br />
(510607) M5Things: Last error captured as transport's socket errno: 0x71<br />
E (510613) mgtt client: mqtt process_receive: mqtt message_receive () returned -2<br />
[INFO] Syncing resources...<br />
[INFO] WiFi connected!<br />
E (512835) i2c: i2c driver install error<br />
Traceback (most recent call last) :<br />
File "main-PY", line 32, in ‹module&gt;<br />
File "main-PY", line 16, in setup File "label plus-Py", line 33, in <em>init</em> ValueError: invalid Timer number<br />
MicroPython v1.25.0-dirty on 2025-06-27; MSSTACK StickC PLUS2 with ESP32 (SPIRAM)</p>
]]></description><link>https://community.m5stack.com/topic/7664/program-upload-error-stickc-plus2</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 16:23:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7664.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Jul 2025 14:12:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Program upload error stickC plus2 on Sat, 12 Jul 2025 14:05:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tssp_projects" aria-label="Profile: TSSP_Projects">@<bdi>TSSP_Projects</bdi></a><br />
Thank you very much! Exactly that problem!</p>
<p dir="auto">Top man and once again thank you!</p>
]]></description><link>https://community.m5stack.com/post/29470</link><guid isPermaLink="true">https://community.m5stack.com/post/29470</guid><dc:creator><![CDATA[marcj091]]></dc:creator><pubDate>Sat, 12 Jul 2025 14:05:35 GMT</pubDate></item><item><title><![CDATA[Reply to Program upload error stickC plus2 on Fri, 11 Jul 2025 12:00:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marcj091" aria-label="Profile: marcj091">@<bdi>marcj091</bdi></a></p>
<p dir="auto">I may have just had the same beginner problem; I got the same error message when I mistakenly used the 'Label+' instead of the basic 'Label' in the UI Editor.</p>
]]></description><link>https://community.m5stack.com/post/29466</link><guid isPermaLink="true">https://community.m5stack.com/post/29466</guid><dc:creator><![CDATA[TSSP_Projects]]></dc:creator><pubDate>Fri, 11 Jul 2025 12:00:26 GMT</pubDate></item><item><title><![CDATA[Reply to Program upload error stickC plus2 on Thu, 10 Jul 2025 03:33:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marcj091" aria-label="Profile: marcj091">@<bdi>marcj091</bdi></a> said in <a href="/post/29438">Program upload error stickC plus2</a>:</p>
<p dir="auto">File "main-PY", line 16, in setup File "label plus-Py", line 33, in init ValueError: invalid Timer number</p>
<p dir="auto">hmmm i think you should pay attention to this line<br />
are you able to show your code?</p>
]]></description><link>https://community.m5stack.com/post/29441</link><guid isPermaLink="true">https://community.m5stack.com/post/29441</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Thu, 10 Jul 2025 03:33:24 GMT</pubDate></item></channel></rss>
