<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Official &quot;OpenAI Vision For AtomS3R-CAM&quot; Firmware Crashes After OpenAI Response (Guru Meditation Error)]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’m having repeated Guru Meditation Errors and reboots with my ATOMS3R-CAM AI Chatbot Kit (8MB PSRAM) using the official firmware.</p>
<p dir="auto"><strong>My setup:</strong></p>
<li>Device: ATOMS3R-CAM AI Chatbot Kit (AtomS3R-CAM+Atomic Echo Base)</li>
<li>Serial monitor: 115200 baud, macOS, arduino-cli</li>
<li>Firmware: OpenAI Vision For AtomS3R-CAM v1.0 from M5burner</li>
<p dir="auto"><strong>Behavior:</strong></p>
<li>Boot sequence completes, WiFi connects, camera detected, OpenAI API key and WiFi SSID/Password read from NVS.</li>
<li>Camera takes a snapshot, sends it to OpenAI, receives a valid <code>chat_response</code> describing the image.</li>
<li><strong>Immediately after printing the chat_response, the ESP32 crashes (Guru Meditation Error: Core 0 panic'ed (InstrFetchProhibited)) and reboots.</strong></li>
<li>This process repeats endlessly.</li>
<p dir="auto"><strong>Example OpenAI response lines before crash:</strong></p>
<pre><code>chat_response: The image appears to show a room with a laptop on a table.
Guru Meditation Error: Core  0 panic'ed (InstrFetchProhibited). Exception was unhandled.
<p dir="auto"><strong>Core 0 register dump and Backtrace</strong></p>
<pre><code>Core  0 register dump:
PC      : 0x00000000  PS      : 0x00060630  A0      : 0x8200e0fe  A1      : 0x3fcb09f0
A2      : 0x3fca6a84  A3      : 0x00000000  A4      : 0x3fcd30d8  A5      : 0x3c1f3d14
A6      : 0x3fcd0a38  A7      : 0x3fcd2448  A8      : 0x8200e0a8  A9      : 0x3fcb09b0
A10     : 0x3fcd0b0c  A11     : 0x3fcd2448  A12     : 0x4200bd28  A13     : 0x00000087
A14     : 0x000000f0  A15     : 0x3fcb0a00  SAR     : 0x00000004  EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000  LBEG    : 0x40056f08  LEND    : 0x40056f12  LCOUNT  : 0x00000000
Backtrace: 0xfffffffd:0x3fcb09f0 0x4200e0fb:0x3fcb0bc0 0x420d2673:0x3fcb0be0
<p dir="auto">Is this a known bug?<br />
Thanks in advance!</p>
]]></description><link>https://community.m5stack.com/topic/7673/official-openai-vision-for-atoms3r-cam-firmware-crashes-after-openai-response-guru-meditation-error</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 09:55:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7673.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Jul 2025 05:52:27 GMT</pubDate><ttl>60</ttl></channel></rss>
