<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Desperately Seriously Need Help Programming&#x2F;Coding!!!!]]></title><description><![CDATA[<p dir="auto">Can someone please PLEASE help tell me what to do with UiFlow 2.0 using a yellow M5 little block sensor thing?? This stuff is like a language from another planet for me and this post is my last resort to figure out how to program/code it for the below:</p>
<p dir="auto">Write a program that will:<br />
a. Read the soil moisture sensor value from the watering unit.<br />
b. Compare the value to a defined threshold (30,000 should do nicely).</p>
<p dir="auto">Also..<br />
Change the LCD color if the value falls below the threshold.</p>
<p dir="auto">THANK YOU EVERYONE THAT CAN HELP IN A DESPERATE SITUATION!!!!!!!!!!</p>
]]></description><link>https://community.m5stack.com/topic/7715/desperately-seriously-need-help-programming-coding</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 09:55:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7715.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 26 Jul 2025 22:50:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Desperately Seriously Need Help Programming&#x2F;Coding!!!! on Mon, 28 Jul 2025 15:00:22 GMT]]></title><description><![CDATA[<p dir="auto">did you looked here by chance?</p>
<p dir="auto"><a href="https://uiflow-micropython.readthedocs.io/zh-cn/latest/units/watering.html" target="_blank" rel="noopener noreferrer nofollow ugc">M5 watering unit</a></p>
]]></description><link>https://community.m5stack.com/post/29638</link><guid isPermaLink="true">https://community.m5stack.com/post/29638</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 28 Jul 2025 15:00:22 GMT</pubDate></item><item><title><![CDATA[Reply to Desperately Seriously Need Help Programming&#x2F;Coding!!!! on Mon, 28 Jul 2025 10:45:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sparklesforever" aria-label="Profile: SparklesForever">@<bdi>SparklesForever</bdi></a><br />
what is "yellow M5 little block sensor" specified?</p>
]]></description><link>https://community.m5stack.com/post/29635</link><guid isPermaLink="true">https://community.m5stack.com/post/29635</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Mon, 28 Jul 2025 10:45:16 GMT</pubDate></item><item><title><![CDATA[Reply to Desperately Seriously Need Help Programming&#x2F;Coding!!!! on Sun, 27 Jul 2025 17:33:06 GMT]]></title><description><![CDATA[<p dir="auto">for start: what hardware do you have for this task, are you able to update firmware via M5Burner to your controller?</p>
]]></description><link>https://community.m5stack.com/post/29624</link><guid isPermaLink="true">https://community.m5stack.com/post/29624</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Sun, 27 Jul 2025 17:33:06 GMT</pubDate></item></channel></rss>
