<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Roller485-Lite power supply]]></title><description><![CDATA[<p dir="auto">Hi all! My first post here...</p>
<p dir="auto">I'm planning to use a Roller485 to implement some simple machine control. I'll be using a M5Stack Core2 or similar to drive it via the I2C port, but I think that I will probably need the power levels of the PWR485 port.</p>
<p dir="auto">Looking at the schematic, it looks like there is a blocking diode that will permit power to be supplied through the PWR485 port, but control to be provided through the I2C port - is this correct?</p>
<p dir="auto">Many thanks in advance!</p>
]]></description><link>https://community.m5stack.com/topic/7717/roller485-lite-power-supply</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 13:50:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7717.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Jul 2025 15:09:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Roller485-Lite power supply on Mon, 28 Jul 2025 12:17:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kuriko" aria-label="Profile: kuriko">@<bdi>kuriko</bdi></a> A follow-up question, if I may...</p>
<p dir="auto">Can an M5Stack controller accept power from the Grove connector? If I connect an Atom-Lite to a Roller485Lite via the I2C port and supply 12V to the Roller485 through the PWR485 port, will this provide power to the Atom-Lite? There appears to be a path through the schematics...</p>
<p dir="auto">TIA</p>
<p dir="auto">Martin</p>
]]></description><link>https://community.m5stack.com/post/29637</link><guid isPermaLink="true">https://community.m5stack.com/post/29637</guid><dc:creator><![CDATA[maby2001]]></dc:creator><pubDate>Mon, 28 Jul 2025 12:17:08 GMT</pubDate></item><item><title><![CDATA[Reply to Roller485-Lite power supply on Mon, 28 Jul 2025 11:12:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kuriko" aria-label="Profile: kuriko">@<bdi>kuriko</bdi></a> Excellent - many thanks!</p>
]]></description><link>https://community.m5stack.com/post/29636</link><guid isPermaLink="true">https://community.m5stack.com/post/29636</guid><dc:creator><![CDATA[maby2001]]></dc:creator><pubDate>Mon, 28 Jul 2025 11:12:59 GMT</pubDate></item><item><title><![CDATA[Reply to Roller485-Lite power supply on Mon, 28 Jul 2025 09:45:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maby2001" aria-label="Profile: maby2001">@<bdi>maby2001</bdi></a><br />
If you use a Roller485, you can connect directly to PortA of the Core2 to provide power + I2C control at the same time.</p>
<p dir="auto">Yes, you can use the 485 bus to provide power and I2C control at the same time.</p>
]]></description><link>https://community.m5stack.com/post/29634</link><guid isPermaLink="true">https://community.m5stack.com/post/29634</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Mon, 28 Jul 2025 09:45:51 GMT</pubDate></item></channel></rss>
