<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Voice assistant with ai agents comunication project - help!]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I've been working on a project with my LLM module. So far, I've only managed to create a chatbot using n8n, which sends questions to the LLM module and receives answers. This is all running through a FastAPI server temporarily hosted on my PC.</p>
<p dir="auto">I've been experimenting with the LLM module and have run into a few challenges. My goal is to build a voice assistant in Portuguese using my CoreS3 connected to the LLM module, which communicates with other AI agents via n8n. However, I haven't been able to find any TTS model that supports Portuguese. From what I’ve seen, the LLM module only includes MeloTTS, which supports only English and Chinese.</p>
<p dir="auto">I’ve tried using PiperTTS, which does support Portuguese, but I haven’t been able to get it working. I also want to know if it's possible to use OpenAI's API tools with the LLM module.</p>
<p dir="auto">So basically:<br />
– Is it possible to install other TTS models on the LLM module?<br />
– Is it possible to use OpenAI API tools with it?<br />
– And if so, how could I implement communication between agents using the LLM module?</p>
<p dir="auto">If anyone could help me with any of these questions, I’d really appreciate it. Cheers!</p>
]]></description><link>https://community.m5stack.com/topic/7725/voice-assistant-with-ai-agents-comunication-project-help</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 10:22:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7725.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Jul 2025 16:14:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Voice assistant with ai agents comunication project - help! on Fri, 22 Aug 2025 18:08:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sinovacao" aria-label="Profile: sinovacao">@<bdi>sinovacao</bdi></a> This is exactly what I was working on trying to setup in english yesterday but was having issues connecting the model to N8N. Would you mind sharing your process step by step?</p>
]]></description><link>https://community.m5stack.com/post/29831</link><guid isPermaLink="true">https://community.m5stack.com/post/29831</guid><dc:creator><![CDATA[webmaster]]></dc:creator><pubDate>Fri, 22 Aug 2025 18:08:12 GMT</pubDate></item></channel></rss>
