<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lora module P2P mode not receiving]]></title><description><![CDATA[<p dir="auto">Trying to get a pair of LoraAS923 units working in P2P mode, using AtomS3.</p>
<p dir="auto">Sending is reported as working, but the second unit will never receive.  I've triple checked all parameter settings, they match on both units.</p>
<p dir="auto">Has anyone actually got this working (on this or other frequency units?).</p>
]]></description><link>https://community.m5stack.com/topic/7740/lora-module-p2p-mode-not-receiving</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:09:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7740.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Aug 2025 01:31:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Lora module P2P mode not receiving on Fri, 08 Aug 2025 07:01:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/adamm5" aria-label="Profile: adamm5">@<bdi>adamm5</bdi></a></p>
<p dir="auto">Well ChatGPT solved my problem....increasing the spreading factor to 11 has suddenly made everything work. Not sure why such a high SF would be needed between two devices on the same desktop? Will soon find out.</p>
<p dir="auto">In the meantime, the following table gives some interesting perspective on the transmission time for a 19byte payload.</p>
<pre><code>SF	Symbol Duration	Payload Symbols	Total Symbols	Airtime
7	1.024 ms	37	51.25	0.052 s
8	2.048 ms	37	51.25	0.105 s
9	4.096 ms	37	51.25	0.210 s
10	8.192 ms	37	51.25	0.420 s
11	16.384 ms	37	51.25	0.839 s
12	32.768 ms	37	51.25	1.678 s
]]></description><link>https://community.m5stack.com/post/29706</link><guid isPermaLink="true">https://community.m5stack.com/post/29706</guid><dc:creator><![CDATA[adamm5]]></dc:creator><pubDate>Fri, 08 Aug 2025 07:01:06 GMT</pubDate></item></channel></rss>
