<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Paper S3 flashing issue]]></title><description><![CDATA[<p dir="auto">I'm flashing the Paper S3 from the Arduino IDE.  The documentation tells you to long press to enter a mode that accepts new code.  The problem is that the Paper S3 only stays in that mode for ~5s and then restarts.  Compiling and flashing in the Arduino IDE often takes 15-30 seconds.  So I'm trying to time the Paper S3 into the right mode so the code finishes compiling within the 5s window.   It usually takes me 4-5 attempts to flash, watching the little progress bar and guessing when to hit the reset button.  Does anyone have a better way to do this?  It's almost unusable like this.</p>
]]></description><link>https://community.m5stack.com/topic/7747/paper-s3-flashing-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:46:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7747.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Aug 2025 00:58:37 GMT</pubDate><ttl>60</ttl></channel></rss>
